compression test
Old Nov 6, 2006 | 05:15 PM
grsford's Avatar
grsford
Default compression test
when doing a compression test what results should i get, and would the results be different with low comp pistons ?
Old Nov 6, 2006 | 06:06 PM
grsford's Avatar
grsford
come on guys please help me on this one?
Old Nov 6, 2006 | 06:10 PM
addiction's Avatar
addiction
somewhere in the region of 150 psi on all four
Old Nov 6, 2006 | 08:35 PM
grsford's Avatar
grsford
i only got between 126 and 130 psi could this be down to lower compression piston and high lift cams etc or is that reading acceptable
Old Nov 7, 2006 | 06:00 AM
JesseT's Avatar
JesseT
It's exactly down to the things you listed. It's only imperative that the readings don't vary too much from cylinder to cylinder.
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
