AVC-R BOOST CONTROLLER
Old Nov 5, 2006 | 05:37 PM
mick320BHP's Avatar
mick320BHP
Default AVC-R BOOST CONTROLLER
as above can you help .i need to identify some wire colours from the ECU im looking for RPM signal or injector signal wire , throttle signal wire and speed signal wire can you help
before i forget its for a 3dr cos on L6 ECU
it would be so if any body could help
cheers mick
Old Nov 5, 2006 | 06:13 PM
mick320BHP's Avatar
mick320BHP
please help ive got faith in passion ford
Old Nov 6, 2006 | 04:48 PM
SafeChav's Avatar
SafeChav
Unfortunately i havent ever come in contact with a cossie so i cant be that much help.
However, things like the injector wire, will be an earth off any injector (as they permentantly have 12v)
RPM wire can be taken straight from the wire on your rev counter.
TPS wire could be found with a multimeter/or from a diagram.
As for speed sensor, if your car doesnt have a speed sensor on the gearbox u will have to fit one.
These wires are all mainly for the extra features, it will still operate as a basic controller for boost without all of them!
Old Nov 17, 2006 | 09:11 AM
sygjim's Avatar
sygjim
so, the apexi can work without all wires ?
Old Nov 17, 2006 | 01:07 PM
SafeChav's Avatar
SafeChav
You can just connect the power wires and run it as a boost controller, its an expensive version of a bleed valve if you do this though.
Without all the wires you cant use the gear selective/rpm based boost and so on....but you could add this at a later date.
Old Nov 17, 2006 | 01:10 PM
sygjim's Avatar
sygjim
thanks
i suppose that we can't use the auto learn feature too ?
Old Nov 17, 2006 | 01:12 PM
SafeChav's Avatar
SafeChav
That auto learn function sets the speed and so on doesnt it if you dont know the output of your sensor(s)
To Which the answer is no......
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
