How can i tell if its from a turbo?
Old Nov 5, 2006 | 08:04 AM
mattrst90spec's Avatar
mattrst90spec
Default How can i tell if its from a turbo?
Hi
Im being offered a rs turbo lsd gearbox, how can i tell if it is a turbo box & has a lsd? The box is already removed from the car!
Cheers Matt
Old Nov 5, 2006 | 08:11 AM
tim10_10's Avatar
tim10_10
If its got a standard ford lsd look through the hole where the drive shafts go, if you see a thick pin running diaganolly across then its not a turbo box. If you see a small round hole then its a got a lsd. Hope that makes some sense. either that or put a drive shadt in if you turn it one way the opposite side should turn the same way.
Old Nov 5, 2006 | 08:50 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Spot on!
Old Jan 30, 2007 | 11:59 AM
slimwynn's Avatar
slimwynn
i'v got a rs turbo box and i did the check where u look where the drive shafts go in and i have no pin but when i spin the wheels in gear they spin the opposite way
Old Jan 30, 2007 | 04:00 PM
XR2's Avatar
XR2
Originally Posted by slimwynn
i'v got a rs turbo box'i did the check where u look where the drive shafts go and i have no pin but when i spin the wheels in gear they spin the opposite way
RST is only 20 - 25% or the diff is totally out of order
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
