head gasket advice - esc cos
Old Aug 28, 2004 | 11:58 AM
bbigman2000's Avatar
bbigman2000
Default head gasket advice - esc cos
Gents
My head gaskets gone,
its a coopers ringed gasket
can anyone advise me on what gasket i need to replace it, and where to buy it cheers guys, am really down about this only just got the car, 700 miles and bang
must it be the same kind of gasket again ? I dont know the difference between the two ?
Old Aug 28, 2004 | 01:12 PM
bbigman2000
anyone help
Old Aug 28, 2004 | 01:14 PM
Karl's Avatar
Karl
Norris Motorsport
All I can say is it's not good news.
Old Aug 28, 2004 | 01:15 PM
bbigman2000
thats very good of you cheers
Old Aug 28, 2004 | 01:18 PM
kjc300's Avatar
kjc300
Amber performance do them, so do GGR and as karl said it's not good news!! especially when you see the price as you don't really have a cheap option!!
Old Aug 28, 2004 | 01:28 PM
bbigman2000
thanks mate, im not bothered about the price i just need my baby on the road sharpish
thanks for helping much appreciated bud.
Glen
Old Aug 28, 2004 | 01:33 PM
bbigman2000
holy jesus christ Ł385 for coopers head gasket WTF
guys what head bolts should I get with this ?
thanks !
Old Aug 28, 2004 | 01:48 PM
RS500/364's Avatar
RS500/364
long stud is the way if you can aford it while you / if you have the enginge out get it all sorted balanced the work then no worrys for the future
Old Aug 28, 2004 | 01:51 PM
bbigman2000
cheers bud, thanks, i dont think i can stretch to that at the moment, I can maybe get the ARP head bolts and the coopers gasket, that will be Ł500, whilst im at it il do the timing belt and tensioners, and replace the exhaust gasket.
the engines only done 35000 miles and seems sweet as a nut top and bottom end, I cant understand why its gone like this !
it should be already well balanced its its built by rondell stage 3
regards Glen
Old Aug 28, 2004 | 02:00 PM
whitneyd's Avatar
whitneyd
I've heard lots of people have trouble with ringed blocks and headgaskets. If the wire isn't put in perfect it doesn't last long. Good luck
Old Aug 28, 2004 | 02:03 PM
Billabong's Avatar
Billabong
Whitneyd, Coopers ring gaskets are different to wire ringing - generally, and from others and my own experience, Coopers are less reliable.
Old Aug 28, 2004 | 02:05 PM
bbigman2000
cheers bro, as far as I know it lasted 35k miles at 1.6 bar boost, so hopefully it aint to bad and it will last longer once sorted for me as im a steady driver not a thrasher or track day fellow.
will start saving for a new improved engine once I get this sorted
cheers Glen
Old Aug 28, 2004 | 02:07 PM
Billabong's Avatar
Billabong
Your next engine would be far better off with a new block and genuine WRC 4 layer MLS head gasket.
p.s. did you mean Jondel as opposed to Rondell?
Old Aug 28, 2004 | 02:09 PM
whitneyd's Avatar
whitneyd
If you put new wire in make sure that the wires butt together well with the ends as flat against each other as possible. I not positive but I think there is a special heat and re-torque procedure. You should ask around to make sure. It helps to be a perfectionist in this game.
Old Aug 28, 2004 | 02:11 PM
kjc300's Avatar
kjc300
Oh yes!!
Billabong's Avatar
Billabong
Whitneyd - Coopers gasket IS NOT the same as wire ringing!! Not having a go, just don't want Glen to get confused
Old Aug 28, 2004 | 02:14 PM
Disabled Account's Avatar
Disabled Account
Yes I agree, wire ringing + one or the late Es Cos head gaskets is very reliable. If it's done properley wire rings are good for 400 BHP (approx 28 lbs/psi)..and prob even more!
Old Aug 28, 2004 | 02:15 PM
whitneyd's Avatar
whitneyd
Sorry about that. I hear so many people saying Coopers ring and meaning wire ring. To me both aren't the best way to go.
Old Aug 28, 2004 | 02:22 PM
bbigman2000
Jondel yes mate are they any good ?
been browsing for blocks just now LOL wondering if Id be better buying a block hell it will not cost much more than the bloody coopers gasket ahaha
then I can run the proper 4 layer wrc gasket
Billabong's Avatar
Billabong
No worries Whitneyd, of course you were only being helpful
As per Doug, my previous EsCos was wire ringed (properly) and proved very reliable for me.
You know, I nearly posted that it may just work out cheaper in the long run to get a new block (circa Ł600) and go MLS gasket route, but then you may need new pistons etc depending on condition of yours etc... to get the best from the package. Obviously you just want your motor back on the road a.s.a.p. at the moment.
It *may* also be possible to have the Coopers channels 'removed' from the block (it's been mentioned on here before), but I don't know what other issues this may cause as regards compression ratio etc., and it would be an engine out job, but you get to keep your low milage engine intact, and then be able to use a more reliable gasket.
May be worth contacting a tuner direct for your options.
Old Aug 28, 2004 | 02:30 PM
Ian2wdsaffcos's Avatar
Ian2wdsaffcos
Oh shit mate, sorry to hear this
Lads, is it not possible to get the block decked, then fit a WRC Multi layer HG & get it remapped for new c/r? I would have thought so & wouldn't this be a cheaper option than getting another bottom end rebuilt.......especially as the engine is sweet otherwise?
Old Aug 28, 2004 | 02:42 PM
bbigman2000
cheers lads, points all noted thank you, I think what il do for now is take the pain get the coopers gasket, get new standard head studs and fix it for the moment, then what Il do is look for a new engine, that I can put in, once thats in, il get my own low miles motor rebuilt to good spec as per advice from members here.
think thats the way to go, cheers billabong
Old Aug 28, 2004 | 02:44 PM
kjc300's Avatar
kjc300
I think Doug may be able to help you with the engine!!! If he's still got it!!
Old Aug 28, 2004 | 02:45 PM
kjc300's Avatar
kjc300
https://passionford.com/forum/viewto...light=#1004054
Old Aug 28, 2004 | 03:08 PM
bbigman2000
thanks mate, thats a really nice mota and if it was 2k id consider it, just a bit dear for the moment, il have to get saving !!!!!!!
Old Aug 28, 2004 | 03:18 PM
kjc300's Avatar
kjc300
I'd have had that straight away if came up a couple of weeks earlier!!
But had already decided on the rebuild when it did!!
Old Aug 28, 2004 | 03:42 PM
bbigman2000
dammit yes, looks a bloody good motor mate
Old Aug 28, 2004 | 03:52 PM
Disabled Account
Thanks mate..........
Built by the "Harvester".......so it's the best!
And to stop this post turning into an all out tuner war, I should add:
"Other engine builders/tuners here on PassionFord also build fantastic engines too"
Except the one called IMA.................avoid like the plague
Old Aug 28, 2004 | 04:07 PM
GARETH T's Avatar
GARETH T
hope you have alot of fun in that car once its gasket is fixed,,, look the bollox
Old Aug 28, 2004 | 04:22 PM
bbigman2000
thanks Gareth, am really glad I broke the Jap mindset, bloody good people here
Old Aug 28, 2004 | 04:24 PM
GARETH T's Avatar
GARETH T
we do try and please,, there is a cracking bunch of people and there is some very knowlagable people on here
Old Aug 29, 2004 | 05:02 AM
bbigman2000
Agreed and thanks bud, will get the car into the workshop and stripped start of the week, il take photo's of whats found for forum discussion
bb
Old Sep 1, 2004 | 03:17 PM
whitneyd's Avatar
whitneyd
I found a gasket for you but you have to hurry!!!!
Chopshop85
Sep 12, 2015 06:42 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
