charge cooler info?
Old Nov 2, 2006 | 03:09 PM
liamford's Avatar
liamford
Default charge cooler info?
how is the water pumped around the charge cooler system??
does changing the charge cooler rad for an uprted one make a big difference??
cheers
Old Nov 2, 2006 | 08:33 PM
Focus-Pocus Estate's Avatar
Focus-Pocus Estate
via a seperate electric water pump located inside the passenger wheel arch behine the airbox assy!!...these retail at over £1600 from ford!
you can buy them for approx £100 on the net!
Yes in the engine running temperature as the turbo charged air is cooler being put back through the engine...possibly a little gain in power too!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
