2wd head
Old Nov 2, 2006 | 02:32 PM
cossieboyIOW's Avatar
cossieboyIOW
Default 2wd head
what things need to be changed and how much hassle is it to put a 4wd engine into a 2wd cossie??
i bought another engine to go in my 2wd out of a 4wd as the big end went on my car... matey who fixed it put the 4wd bottom part into my car and put my old 2wd head on top... but is it simple to put a 4wd on there? the cylinder head cracked after about 1500 miles so am lookin for another head (as per sheps thread in wanted!) but they seem to be getting scarce lol
Old Nov 2, 2006 | 03:40 PM
bud-weis's Avatar
bud-weis
Football Cwazy
straight swap as far as i know, you'll need to plug the oil feed for the turbo though and use the 2wd setup from the inlet side of the block,
Old Nov 3, 2006 | 03:06 PM
sheps's Avatar
sheps
Ah so why was this matey who is fixing his car on about having to change temperature senders and all sorts of gubbons??
Old Nov 3, 2006 | 04:41 PM
jon@work's Avatar
jon@work
if you're replacing a 2wd head with a 4x4 head then :
the temp senders for the temp gauge are in different positions (2wd front drivers side, 4x4 rear pasenger side)
the 4x4 head doesn't have the mounts for the turbo damper - if you're using a 2wd exhaust manifold, you'll need to use something like the Bailey turbo damper
you'll need to use the 2wd thermostat housing, unless you fit a 4x4 water pump
you'll need to blank off the turbo oil feed if using the 2wd feed pipe, or screw the oil pressure sender straight into the block if using the 4x4 oil feed pipe
Old Nov 3, 2006 | 08:25 PM
costina's Avatar
costina
Live long and prosper!!
2wd heads on 4x4 blocks = lower comp, i'd put the 4x4 head on as its a better design
And take note of what jon's post says
Old Nov 4, 2006 | 12:25 AM
jon@work's Avatar
jon@work
true - and probably not a bad idea considering the amount that has been skimmed off most heads by now
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
