backfire on boost
Old Nov 2, 2006 | 10:41 AM
sy.rst's Avatar
sy.rst
Default backfire on boost
got a prob with my s2 rst when it comes on boost it stop's suddenly like i just hit a brick wall,backfires then pick's up again? could it be a fueling prob? its bn chiped/standard intercooler peaks bout 16psi and holds bout 10. if thats any help, cheers
Old Nov 2, 2006 | 10:54 AM
matt p's Avatar
matt p
Hi mate has it only done this recently or for a while?
Could be something on the ignition side breaking down,
As its getting really cold now it may of overboosted but that maybe
unlikley, feels like its backfiring but useally a little more violent
Old Nov 2, 2006 | 11:18 AM
buggynut's Avatar
buggynut
i had the same probem with mine last week and turned out to be the altenator was shagged
Old Nov 2, 2006 | 01:00 PM
SafeChav's Avatar
SafeChav
If its definately chipped it could well be the sensor in the dizzy breaking down.
Old Nov 2, 2006 | 01:09 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Even if it has been chipped, its possible that the boost-cut hasn't been removed altogether. Some raise it to 18psi and it could be hitting that due to a boost spike, probably the result of a weak/poorly adjusted actuator.
That's where my money would be.
Old Nov 2, 2006 | 01:10 PM
SafeChav's Avatar
SafeChav
where were you when a thread kicked off the other weak when people started saying ALL chips remove the boost limit!
Old Nov 2, 2006 | 01:13 PM
Christian and Beccy
#1 in Spelling Club
LOL. I think you will find that Ahmed does an 18psi cut and a 24psi cut. Not really sure why though.
Old Nov 2, 2006 | 01:16 PM
SafeChav's Avatar
SafeChav
Ah right like that is it
Old Nov 9, 2006 | 12:57 PM
sy.rst's Avatar
sy.rst
its only started doing this since i fitted the new actuator, i ajusted the timeing by moveing the dizzy yesterday it seams better now it only seams to do it in 3rd gear when i get to bout 80mph.
Old Nov 9, 2006 | 04:21 PM
SafeChav's Avatar
SafeChav
Boost limit if you ask me.......
Old Nov 9, 2006 | 05:39 PM
antony215's Avatar
antony215
Escort Rs Turbo
I'll second that you've probably set the boost too high if you've put a new actuator on
Old Nov 11, 2006 | 11:59 AM
ShandzS1's Avatar
ShandzS1
U lads mite know.....my s1 is pinking when it comes on boost on hard throttle, any ideas???
Old Nov 11, 2006 | 12:12 PM
Rick's Avatar
Rick
Yes, too much ignition advance and/or too much boost.
Keep at it, and u'll have no engine left...
Old Nov 11, 2006 | 12:15 PM
ShandzS1's Avatar
ShandzS1
it boosts 0.5 bar which is standard, could it be dizzy, or ecu?
Old Nov 11, 2006 | 12:17 PM
Rick's Avatar
Rick
it COULD be a lot of things...
Has it just started doing it?
Old Nov 11, 2006 | 12:29 PM
ShandzS1's Avatar
ShandzS1
it broke a piston ring a while ago, and pulled it 2 bits and fitted new rings, and i reckon since then it hasnt been right
Old Nov 11, 2006 | 12:31 PM
Rick's Avatar
Rick
more compression then. Twist the dizzy to retard the timing a touch, and see how it goes. Should cure it.
Old Nov 11, 2006 | 12:32 PM
ShandzS1's Avatar
ShandzS1
clockwise if looking from the gearbox end?? Also its got bad back pressure tho......
Old Nov 11, 2006 | 12:46 PM
Rick's Avatar
Rick
no, anti clock wise if looking at it from the box. Dont turn it more than a couple of mm.
How do you mean, back pressure issues?
Old Nov 11, 2006 | 01:52 PM
ShandzS1's Avatar
ShandzS1
yeah it blows the cap off when giving it a bit boost, there was a bit of a lip on the block wen i had it in bits
Old Nov 11, 2006 | 02:41 PM
Rick's Avatar
Rick
Blow by. You've left the block as is?
Old Nov 11, 2006 | 04:28 PM
SafeChav's Avatar
SafeChav
Re-build time
Old Nov 11, 2006 | 06:02 PM
ShandzS1's Avatar
ShandzS1
Just gave it a hone out...... rekon it needs re-bore and oversize pistons??
Old Nov 11, 2006 | 06:04 PM
SafeChav's Avatar
SafeChav
You shouldn't really re-bore and use standard pistons, especially the amount you would of honed to remove the wear etc.
You've got to remeber the next size pistons up are 0.5mm oversize.......that soon gets used up in honing
Old Nov 11, 2006 | 06:31 PM
ShandzS1's Avatar
ShandzS1
Well its off the road at the end of the month, so the engine will be out and down 2 the local engineers to get measured up n see wot i need, there was a guy on here selling re-bored s2 block and new 0.5 pistons for £400, but realy want to keep original block..... as its totaly standard and only done 72k
Old Nov 11, 2006 | 08:40 PM
Rick's Avatar
Rick
so what if it's std - its worn to hell!
Old Nov 12, 2006 | 02:01 PM
SafeChav's Avatar
SafeChav
Mileage doesnt necessarily reflect anything as you are proving.....its only done 72k...........a very hard 72k by the sounds of it!
A well looked after and maintained engine should be seeing a lot more than that
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
