escort mk2
Old Nov 1, 2006 | 07:11 PM
leon.strong.dslw@onetelds's Avatar
Default escort mk2
hi I need some help. I have fitted biltein adjustable coilovers to my mk2 escort and the tapard hole in the bottom of the leg is bigger than the end of the tca. I have been told that the tca are all the same .
Old Nov 1, 2006 | 08:53 PM
the original's Avatar
the original
yep you're in trouble.
the tca's are all the same
are you sure the hole is tapered?
as it may be for a different setup with a bolt through,
i.e if it came off a car with,say, compression struts and homemade tca's (to widen the track) witha rod end at the end?
pics would help
Old Nov 1, 2006 | 09:25 PM
Wardy257's Avatar
Wardy257
Due you mean TCA, or Track Rod end? The track rod ends do differ.
Old Nov 2, 2006 | 06:22 AM
the original
true, but the steering arms should be bolt-on
that's why pics would help
Old Nov 2, 2006 | 07:30 PM
once my mate shows me how to post pics I will show you my xpack mk2 with cossy and dicky coil overs.
Old Nov 2, 2006 | 09:48 PM
ian sibbert's Avatar
ian sibbert
I think he means where the ball joint on the TCA goes into the hub....
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
