Fiesta turbo distortion problem
Old Oct 31, 2006 | 08:07 PM
PAULDOLMAN's Avatar
PAULDOLMAN
Default Fiesta turbo distortion problem
Hi
I’ve got a problem with my fiesta rs turbo I’m hoping someone might be able to help or to suggest something
The problem is a virbration/distortion through the pedals over 30mph when going straight or right the more you go right the worse is gets, if the car turned left the problem is solved
This is what I’ve tried so far –
- at the rear It’s recently had new rear hubs, bearings, alloy caliper brakets, new discs & pads
- at the front the front left coilover shock has been leaking which was changed, new track rod ends, tracking checked & adjusted front wheel bearing checked and all seem ok
can anyone please suggest anything else
regards
paul
Old Oct 31, 2006 | 08:22 PM
NEWTON's Avatar
NEWTON
cv joint
Old Nov 1, 2006 | 08:53 AM
SafeChav's Avatar
SafeChav
CV joint seconded, and i would bet a jam tart its the N/S one
Old Nov 1, 2006 | 05:22 PM
PAULDOLMAN's Avatar
PAULDOLMAN
thanks guys for the advice i'll order them 2morrow
Old Nov 1, 2006 | 05:26 PM
SafeChav's Avatar
SafeChav
Might be worth giving it a once over before ordering them just incase!
Wouldnt want to make you spend money un-necessarily
Old Nov 1, 2006 | 10:30 PM
NEWTON's Avatar
NEWTON
as above give them the once over
carlo
24
Oct 5, 2015 08:20 PM
druidgetafix
Aug 15, 2015 10:22 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
turbobill
Aug 1, 2015 08:55 PM
