Obsolete RS parts
1000046 ALLOY GEARKNOB mondeo mk1,2 and escort mtx75 alloy gearknob
1638320 XR4X4 FRONT OUTER CV BOOT KIT
6088981 HEADLIGHT WASHER PUMP
6157560 ESC SIERRA COS 4X4 INPUT SHAFT BEARING
6672257 SIERRA ESC COS FRONT OUT CV BOOT KIT FROM 9/91 ON
6746274 ESC COS FRONT BUMPER HOCKY STIck
6746275 ESC COS FRONT BUMPER HOCKY STICK
1107891 MONDEO HEATED SEAT/TRACTION CONTROL SWITCH
1451178 COS OIL PUMP DRIVE SHAFT
1630069 SIERRA XR4I REAR DECAL
1630309 COSWORTH FRONT HUB SEAL X4
1638184 2WD COS TURBO TO INTERCOOLER HOSE
1639249 3DR COS OIL FILLER CAP
1640013 ORION MK 1 N 2 NSR CHASSIS LEG
1644593 3DR SIERRA NSR FLOOR MEMBER
1648243 SIERRA MK2 UPTO 1990 IGNITION SWITCH
1650992 SIEERA MK2 ABS BUSH AND O RING KIT
1651303 2WD COS FUEL RETURN PIPE TO PUMP
1651725 THERMAL TIME CONTROL SWITCH RS TURBO
1652731 XR3I DECAL
1661351 MK4 ESCORT NSF SPEAKER COVER SHADOW GREY
1664250 FIESTA XR2I/RS TURBO OSF JACKING POINT COVER
1666979 SIERRA MK2 DRIVERS SIDE WINDOW SEAL
3870269 MONDEO ST200 AIR CHARGE SENSOR
5022701 2WD COSWORTH STANDARD TURBO DAMPER SERVICE KIT
6062845 PINTO CAM FOLLOWER ARMS
6097991 MK1 SIERRA HIGH PITCH HORN
6105369 MK1 FIESTA NSR BUMPER
6146235 MK4 ESCORT NS ELECTRIC WINDOW SWITCH
6151497 MK2 SIERRA FR BUMPER MOUNTING PANEL
6157285 SIERRA MK1 +2 UPTO 1990 HEATER MOTOR
6184958 3DR COS FRONT ABS SENSOR
6200508 FIESTA MK3 FRONT FOG LAMP SWITCH
6200514 MK4 ESCORT HEATED REAR WINDOW SWITCH
6201329 SIERRA 1990-1993 STEERING COLUMN
6498098 CVH 1.8 CRANKSHAFT
6672258 SIERRA ESC COS 9/91 ON INNER CV BOOT KIT
6680027 SIERRA 1990 ON OS A POST TRIM DAWN GREY
6859703 2LT DOHC 16V CRANK SENSOR
6876468 FIESTA MK3 ENGINE SUPPORT CRADLE
7146469 FIESTA MK3 CONSOLE SHADOW GREY
7258063 TURBO BADGE (OF A TRANSIT)
7334614 COSWORTH 24V TAPPETSX6
8000112 FOCUS STAINLESS STEEL GRILLE
1637872 2WD COS + 3DR REAR PADS
5007027 FIESTA MK1 REAR WHEEL BEARING
5021410 ESCORT MK3 + 4 TRACK ROD END
5021456 MK3 ESCORT OSF ARM
5022656 MK2 XR2 FRONT DISCS
5022667 SIERRA COSWORTH 2WD + 3 DOOR REAR DISCS
5051595 MK5+ 6 ESCORT REAR SPOILER
6136490 MK4 ESCORT FRONT FLASHER LAMP N/S
6525817 SIERRA COSWORTH 4X4 LOWER RAD HOSE
6704269 ESCORT RS TURBO FRONT PADS S2\
6962759 SIERRA4X4 + ESCORT COSWORTH NSR DRIVE SHAFT
6185941 MK4 ESCORT MASTER CYLINDER NON ABS ( POSS SOLD)
MORE DETAILS HERE
http://www.rs-mania.co.uk/forums/ind...howtopic=17261
1652731 XR3I DECAL
MORE DETAILS HERE
