its a girth thing
right i will be running a set of 7.5 x 17 rl7 for the track and im looking at what tyres to use
whats the widest tyres you have had on?
thinking 225-40-17
anyone recomend any tyres also
r888's
thinking 225-40-17
r888's
can you not go for a smaller wheel? 17's are a little big for ultimate handling. On the back, stick to 205/40's. 225's would be fine on the front, even 235's if u get them to clear the arches. The wider the tyre, the less predictable the handling will be, and it can tramline at speed. It's not so much of a problem on the front, but on the rear if the tyre is wide - the rear end will break away without any warning.
cheers for input
i have fully adjustable everything so been told that he will be able to make 17's handle just aswell
i do have some oz mags in the 16" variety (if really needed)
has anyone had 235 on the front then?
Mark_
40
Oct 2, 2015 04:40 PM
rsguy
44
Sep 29, 2015 03:29 PM
