Strange RR Results? **NOW WITH GRAPHS**
Old Oct 31, 2006 | 04:59 PM
sheps's Avatar
sheps
Default Strange RR Results? **NOW WITH GRAPHS**
Ok,i went to P.T.S. on Saturday for a RR run, i came back with 186bhp at the fly, and 234 torque!!!
ive never thought there would be that much difference between the two?
any ideas why it is?
AFAIK the only mods i have are:
Full exhaust
Chip (running 15psi)
Cosworth fuel pump.
But i do think the Gearbox is a diesel with an lsd. Would this make any difference?
Old Oct 31, 2006 | 07:03 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Can you scan the graph and post it?
That does seem like a little too much Torque. Wheelspin could cause that amongst other things.
Without wanting to sound awful, 186bhp is probably a little on the high side too. Does it have a standard Intercooler?
Old Oct 31, 2006 | 07:20 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Real RST gearbox's all have LSD anyway.
Wouldn't diesel gearbox's just be a bit stronger and maybe have different gearing in (which would not influence power, just acceleration and top speed) ?
Old Oct 31, 2006 | 07:38 PM
sheps's Avatar
sheps
Will try and get the graphs scanned in.
yes it was a standard intercooler.
i bought the car with the mods unknown,so those are the only mods i can prove, ive always thought there must be something extra done, but cant prove it?
ive always thought it is very quick for what it is.
the gearing on the box is long, well over 120 in 4th gear, but it defo has an lsd.
oh, and peak power is at 5000rpm...also i hit the redline at 6000rpm.
Old Oct 31, 2006 | 07:48 PM
Šhatter Box's Avatar
Šhatter Box
diesal gearbox stonger but it will not have an lsd in it where u hear that max power its all ways better to have more tork imo my old black s2 had 190bhp with 215 pounds of tork!!!!
Old Oct 31, 2006 | 08:01 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
PTS rollers have a habit of reading high on torque i think
When i had my zvh power tested it came out with 235hp 300lbs @ 14psi. I know the zetec/zvh's are torquey engines but thats steep.
Old Oct 31, 2006 | 08:47 PM
scotty86d's Avatar
scotty86d
diesel gearboxes arent stronger are they?just have taller gearing.and 186 bhp on a standard cooler, impressive although never knew that was all that achievable. If true, kick on though to you!!
Old Oct 31, 2006 | 09:09 PM
Christian and Beccy
#1 in Spelling Club
High Torque readings usually indicate slip of some kind. There may have also been an issue with RPM accuracy. Did the operator connect anything to the engine? For example a 'clamp' onto an HT lead?
If not, he may have relied on the car's tacho for an RPM reading and these are usually MILES out, which would have an impact on the result.
Also, Alex, will you PURLEEEEEASE learn how to spell TORQUE.......
It's T O R Q U E.
Get it??!!
Old Nov 1, 2006 | 09:08 AM
SafeChav's Avatar
SafeChav
Diesel gearboxes aren't stronger at all, they just have different ratios! So apart from having different sized gears on the shafts, there are identical. Just another urban myth
Of course you could have a diesel box with an LSD fitted, no reason why it couldn't be done
Old Nov 1, 2006 | 10:13 AM
ballin's Avatar
ballin
diesels always make good torque dont they?
cant a fucked bottom end give high torque figures? Sure Paddys did this
Old Nov 1, 2006 | 12:43 PM
sheps's Avatar
sheps
ok, not sure if this will work but here goes....
BHP
Torque
Anyone make any sense?
Old Nov 1, 2006 | 08:25 PM
Rick's Avatar
Rick
no power as it's not revving past 5k.
Old Nov 1, 2006 | 10:56 PM
Christian and Beccy
#1 in Spelling Club
I would say that the rolling road operator had an unreliable method of recording RPM. It's a quick, easy method to use the car's tacho, but with RST tacho's being so far out, the results are usually shit.
I wouldn't have expected an RST to stop making power at 5k, even on a standard turbo.
Old Nov 2, 2006 | 11:27 AM
sheps's Avatar
sheps
Hmmm going be my cars tacho, the needle will hit the redline at 6k(ive had two different sets of clocks in there), then it bounces and its like hitting a brick wall
So shite operator?
and still, whats the reason for having so much torque? compared to a more than average power?
Old Nov 2, 2006 | 01:12 PM
Christian and Beccy
#1 in Spelling Club
The figures are pretty much scrap if the RPM reading was wrong. Next time you go, quiz the guy over what he uses to read RPM. If they could be bothered, they could use a pick-up that goes onto a plug-lead. It's hardly difficult, just some would rather wing-it and use the tacho.
If you want a good reliable figure, find someone with a Dyno Dynamics Dyno.
Old Nov 2, 2006 | 03:56 PM
sheps's Avatar
sheps
Hmm the next time i go on a RR shall be a full set up, with the new engine.
any recommendations on where to go? bairing in mind im on the isle of wight :AJ:
Old Nov 2, 2006 | 05:53 PM
Oranoco's Avatar
Oranoco
I just happen to know the UK man for thses. Top bits of kit and what we are playing on on Saturday
Old Nov 2, 2006 | 09:12 PM
Rick's Avatar
Rick
Steve - that makes NO sense
Old Nov 3, 2006 | 01:40 PM
chelseabully1's Avatar
chelseabully1
this is what i got yesterday engine advantages and i have a diesel gbox
as you can imagine im am well pleased
Old Nov 3, 2006 | 03:04 PM
sheps's Avatar
sheps
So it looks like a diesel box does your torque some good then??
Old Nov 3, 2006 | 03:15 PM
dave_y's Avatar
dave_y
here is the graph i got from PE when i had 15psi on standard cooler
Old Nov 3, 2006 | 07:21 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Now thats interesting as I'm running the same spec at the moment. Just cut out the bumper to provide better air flow to the intercooler. Don't know how fit my engine is, though. Have you ever done a compression test, dave?
Old Nov 3, 2006 | 10:25 PM
dave_y's Avatar
dave_y
nope, never done a comp test.
shes as fit as a fiddle at the moment
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
