Which Fuel Pump
HI!
I will start to upgrade my 4x4 Sierra in the next few weeks.
Will install 803 greens with 3 bar map sensor++++ to reach appr. 300bhp.
I will also change the fuel pump so what type of pump shall i
buy? I think the 044 Bosch is far to big for this purpose, so what
will be the best price/effort? Webasto? Original new Bosch pump?
regards
Mathias
regards
Mathias
It ends in 044! PM bosh-man on here and ask him
as for the fuel pump best to get it rewired as a percaution should cost
around 80-100 with bits and fitting
044 pump will be fine
Is this pump the correct?
If with which dealer I can buy one in such a way? This dealer would have to be able to send also to Germany parts away.
send "bosch-man" (phil) a PM and he will be able to supply you with a pump
you will also need a fixing in the pump to connect to the standard fuel feed pipe from the tank - again ask Phil
Originally Posted by llw
to run 330 brake
cant the standard fuel pump cope?
or is it necessary to change
make sure that you change the fuel filter if it hasn't, to your knowledge, been changed
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
