bloody reverse :wall:
SOOOOOO fookin difficult to get into reverse gear... sometimes itjust dont wanna engage... temperemental
doing my tits in
oh well, good job ive got a B&M quickshift coming tomorrow so it'll sort out that little problem... lol i must be psychic
so guys, you MAY have to help me push the car backwards tonight
doing my tits in
B&m replaces the whole gearstick n linkage n shit, also its new so not worn
also bloke fitting it can havea good old butchers whilst he's sorting it
ps its an MT75
ps its an MT75
B&M Shifters are totally shite IMO Hated mine back to standard now,even karl didnt like it either he took it off the box i sold him so if you want 1 for a t5 box mail karl im sure u will get it at a good price.
Tim
Tim
Originally Posted by B16 RBM
What box have you got?
If its a t5 try engaging 4th gear and then reverse
hope that might be of help to you
My mate has to do this,otherwise reversing aint happening
Tim
Tim
That always seems to be the case on T5s. Bro has one too, and it makes the change feel so hit and miss..........
quick shift aint good on a t5, shifts too quick for the gears, ask bernie, he dont like em either i belive
a cossie aint got a long shift anyway, but the 2.0glsi has a fooking silly shift
Did one of your other posts say the lift up collar is inside your gaiter?
If so, you probably aren't lifting it all the way, and there is a metal pin that stops the lever moving across.
If you put the gaiter down below the collar where it should be, so you can use the lift-up properly, it could solve the problem.
all sorted now
would like to say a big thanks to bernie for talking me through some possibilities earlier
also a big thanks to craig @ the place i cant rememer the name of
(cossymad's mechanic) for fixing it... and for cossymad for putting me intouch
it was the rubber gaiter around the gearstick getting stuck where the lift up reverse gate was, so you couldnt pull the gearlever far enuf back to engage properly
i'm SOOOO glad its sorted now as it was getting embarrasing having people help me pusht the car backwards
also got the quickshift on there now... its BRILLIANT!
The Enigma
Sep 12, 2015 10:12 PM
