losing oil???
Old Oct 29, 2006 | 12:58 PM
kurdt5's Avatar
kurdt5
Default losing oil???
what causes a car to lose oil without a oil leak??
of s1
Old Oct 29, 2006 | 01:27 PM
Rick's Avatar
Rick
engine is burning it. 2 most likely causes are valve stem oil seals, and worn rings/bores.
Old Oct 29, 2006 | 01:47 PM
kurdt5's Avatar
kurdt5
can these be repaired?
Old Oct 29, 2006 | 01:50 PM
Rick's Avatar
Rick
valve stem oil seals are easy enough yes. Bores/rings is engine rebuild. Does it smoke at all? How much oil is it using?
Old Oct 29, 2006 | 01:54 PM
kurdt5's Avatar
kurdt5
funny thing is the car doesnt smoke, there's no oil leak.
just thought id check the oil and it seems bone dry!!
just put mobile 1 in and its registering on the dip stick, car usually runs fine and quiet.
think i checked the oil 2 months back was just under the max.
Old Oct 29, 2006 | 02:04 PM
JamboRS's Avatar
JamboRS
focus rs 1672
could it be a breahter issue and oil is being sucked thru the i/c
had issues with my cars breathers and emptied 2litres of oil out the i/c(which is a grs),worth checkin anyway
Old Oct 29, 2006 | 02:06 PM
kurdt5's Avatar
kurdt5
i'll check that out in a mo cheers!!
how much is a rebuild by the way?
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
