Help needed on battery going flat
Old Oct 28, 2006 | 03:19 PM
jamie rst's Avatar
jamie rst
Default Help needed on battery going flat
As above help needed on my dads car its a 4x4 sapphire cosworth and the battery keeps going flat on him it has got a new battery on the car if he use the car every day it does not go flat but as he only use the car at the weekend i was just asking incase any one as had this problem before as it is doing my head in
Thanks for any help on this
Old Oct 29, 2006 | 11:23 AM
rabmc's Avatar
rabmc
Mmmm had a simalar problem about 2 times and most recently on my 3 door , all times its been at my alternator , theres a blue wire goes ont a thread , shouldbe the same colour i think on yours , anyway i think this sends a signal to the battery to charge it ? i might be wrong , but 99% sure , anyway had this type of problem recently and checked it out the other week and mines was all split and corroded , got new connector , redone the connection and shes been great since , bought a new battery too before finding this
Maybe even worth cleaning it up just incase , even if it looks ok
Old Oct 29, 2006 | 02:57 PM
G2 FSR's Avatar
G2 FSR
Sounds like its not holding its charge? Try and change the alternator, check connections on the coil also
Old Oct 29, 2006 | 10:15 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine also does it
I just think its my alarm draining it.
Steve.
Old Oct 30, 2006 | 07:51 PM
jason_nike's Avatar
jason_nike
Both mine drain too, mostly the alarms but a trickle charge for 24 hours and back to normal
Old Oct 30, 2006 | 08:16 PM
Wardy257's Avatar
Wardy257
Do go changing anything until you have done some proper tests. Have a look at this:
http://forum.fordsierraclub.co.uk/viewtopic.php?t=18853
Volt drop your alternator and do an amps draw test on your batery.
Old Oct 30, 2006 | 08:23 PM
jamie rst's Avatar
jamie rst
Thanks lads i will be on it this weekend to see if i can find the problem
ONCE AGAIN THANKS FOR THE HELP
cameron2
Aug 19, 2015 09:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
tankybaby66
Aug 9, 2015 07:13 AM
xr_craig
Aug 7, 2015 06:00 PM
col93saphcos
Aug 7, 2015 03:21 PM
