5w/50 oil for a s2?
Old Oct 28, 2006 | 10:36 AM
chris^si's Avatar
chris^si
Default 5w/50 oil for a s2?
i bought some motorsport 5w/50 for my s2, and since using it i've ended up with a oil leak? could the viscosity be too thin?
never leaked before i changed oil.
Old Oct 28, 2006 | 11:55 AM
swerv's Avatar
swerv
wont cause an oil leak, you have other problems.
check sump nut and filter.
Old Oct 28, 2006 | 01:15 PM
JamboRS's Avatar
JamboRS
focus rs 1672
is 15/50 not the recommended oil for an rst
anyway wheres the oil leak from? sump gasket?
i had a [prob with my engine breathers and had an oil leak from the sump gasket because of the presure,looks for the easiest route out,now the breathers sorted its stopped
Old Oct 28, 2006 | 01:58 PM
chris^si's Avatar
chris^si
no its coming from the turbo somewhere on the underside.
Old Oct 28, 2006 | 03:18 PM
marky_g's Avatar
marky_g
Fleet Manager
its ur braided oil return pipe try that
ford suggest 10/40 full synthetic oil
ive used 15/40 and it killed a turbo!
Old Oct 28, 2006 | 05:41 PM
JamboRS's Avatar
JamboRS
focus rs 1672
check the oil return hose to the block
Old Oct 28, 2006 | 09:05 PM
buggynut's Avatar
buggynut
so what is the correct oil to use?
i hear alot of people use mobile 1 15w/50
Old Oct 28, 2006 | 09:09 PM
Šhatter Box's Avatar
Šhatter Box
when the s2 was new from fords the oil was 5/50 but now times more on its 15/50 mobie one
Old Oct 29, 2006 | 12:49 AM
antony215's Avatar
antony215
Escort Rs Turbo
It all depend's on how tuned your car is and what you use it for e.g track day's or just everyday driving i put 5/40 full synthetic in mine and the oilman said that would be fine as it's standard and i only use it for everyday driving no track day's or anything. If you want to know what oil to use give him a PM with the spec and what you use your car for and he'll tell you what will be best
Old Oct 29, 2006 | 06:02 PM
marky_g's Avatar
marky_g
Fleet Manager
i lookin on the chart i ford parts dealers and its reccomends 10/40 full sin for the ERST,
thats what i use, ask a few tuners what they would put in, think 15/50 is the wrong weight
Old Oct 30, 2006 | 03:44 AM
antony215's Avatar
antony215
Escort Rs Turbo
Yeah that's when they were new like i say it all depends on what you use the car for as to what oil you should put in
Old Oct 30, 2006 | 06:32 PM
marky_g's Avatar
marky_g
Fleet Manager
yer just use part sin then gotta get the right weight
Old Oct 31, 2006 | 05:18 PM
chris^si's Avatar
chris^si
so is oilman the bloke to ask? im not running massive power, 200bhp max and its used everyday.
Old Oct 31, 2006 | 06:36 PM
marky_g's Avatar
marky_g
Fleet Manager
get a 2nd opinion im using 10w/40 im Running about 180 break and its off the road but i would use it everyday
Old Oct 31, 2006 | 06:58 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yeah give him PM and he will tell you what's the best grade to use and he can supply it for you too
Old Oct 31, 2006 | 08:08 PM
chris^si's Avatar
chris^si
sweet i'll give him a buzz, is his user ID just oilman? i'll search him in members listings
Old Oct 31, 2006 | 08:47 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yes mate here you go https://passionford.com/forum/profil...rofile&u=14407
Old Oct 31, 2006 | 10:18 PM
makaveli96's Avatar
makaveli96
I used to put in 15/50 mobie 1 for the past 3 years and never had a problem but now I put im 10/60 millers for almost a year now and still don't have any problem my rs is almost standard never been chipped
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
