PC questions- simple
jake go and find on www.snapfiles.com and in to the freeware section and search for " windows clean up",it does ALL you need to do but be care full how you configure it
go in to options and check these box's:
delete news groups subscriptions
delete help index gid files
delete prefetch files
scan local files for temp files
clean up all users
and make sure you are on custom clean up
oh make sure you dont fully erase files
clean up all users
You also need to clean out the file called index.dat
You'll need a special program to do this, but it is pretty straightforward
Just type 'index.dat' (without the quotes, obviously) into google and that should come up with some ways to do it.
Ronnie Scott
Sep 20, 2015 10:21 PM
