Help needed with new engine asap
Old Oct 27, 2006 | 05:01 PM
rst steve's Avatar
rst steve
Default Help needed with new engine asap
Ok just put my engine back in and the sodding thing wont start turns over fine but just wont fire checked the plug leads are on the right way they are fine sounds like its not getting fuel but there is fuel at the metering head coming from the fuel filter and at the individual pipes for the injectors so i am stuck any help would be cool thanks.
Old Oct 27, 2006 | 06:46 PM
radiant red's Avatar
radiant red
Default Re: Help needed with new engine asap
take it you have a spark??is it trying to start?have you tried slightly pressing the airflow meter whilst carnking?
Old Oct 27, 2006 | 09:17 PM
rst steve's Avatar
rst steve
Getting a spark will try doing that with the airflow meter tommorow as the batterys flat now If that does'nt work think i'm going to set fire to it
Old Oct 27, 2006 | 09:51 PM
radiant red
trouble k jet mate its very sesative to pressure drops etc they require around 6 bar to function,if ya get sick of it ill give you Ł100
Old Oct 27, 2006 | 10:19 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
timing 180 out?
Old Oct 27, 2006 | 10:55 PM
JjCoDeX75's Avatar
JjCoDeX75
I had the same problem on my cossie, which turned out to be me putting the phase sensor back in wrong - phase sensor was right, but plug inside the dissy was wrong way round.
This will only be helpful if you (a) have one and (b) you have messed with it
Drove me mad though on mine
JJ
Old Oct 27, 2006 | 10:58 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
RST will have fuel at the metering head, but you'll need to press the flap down and crank it to get fuel put the injectors
Old Oct 28, 2006 | 11:20 AM
rst steve's Avatar
rst steve
Ok just started on the car again and starting to think that the starter motor is goosed had the battery on charge last night so fully charged but the starter is still very very slow to turn the engine over if i take the plugs out and try it it speeds up considerable i am getting spark on every plug and the plugs are wet so must be getting fuel just does'nt seem as though its turning over fast enough to start add to this the fact that if i try to start the car for anything longer than about 5 seconds there is smoke coming from the starter
Old Oct 28, 2006 | 02:23 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Have you checked all the earth straps / wires are connected ?
Steve.
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
col93saphcos
Aug 7, 2015 03:21 PM
