Mk4 escort zetec conversion
Old Oct 26, 2006 | 07:54 PM
xrmalin's Avatar
xrmalin
Default Mk4 escort zetec conversion
Hello there every boby ive recently been offered a 2Ltr mondeo engine to put in my car through a friend of a friend,ive been thinking of doing a zetec conversion for a while now and its brought up a few questions the engine will come with all the ancilaries and the inlet and exhaust manifolds along with the mondeo wiring loom and ecu.I already have the modified engine mount thats required to fit it in the bay and i know i need a sump and water pump off a 1.8 escort zetec also that i can use my gearbox after a slight mod to the cvh flywheel the things im not sure about are wether the mondeo wiring loom and ecu would be ok to use instead of an escort one.Also wether to use a radiator off an escort or mondeo and which pipes to use.I think that should be enough for the time being thanks for all your advice in advance
Old Oct 29, 2006 | 02:48 PM
16vzetec's Avatar
16vzetec
look on my site: www.16vzetec.com
Old Oct 30, 2006 | 05:34 AM
JesseT's Avatar
JesseT
On your site it says:
The mondeo oil pump fits on the escort and fiesta but it spins in the opposite direction so will pump the wrong way on the escort.
This can't be right as the crank turns the oil pump directly and the engines definately don't rotate the other way?
Old Oct 30, 2006 | 08:27 PM
Wardy257's Avatar
Wardy257
It is the waterpump that spins the wrong way on the 2.0 ltr, that is of course of you do not keep the PAS pump etc.
Old Oct 31, 2006 | 12:35 PM
16vzetec's Avatar
16vzetec
yes i believe you are right but it must pump different as i had a mondeo and escort pump side by side and they have the turbine part of the pump pumping opposite ways on each them!
Old Oct 31, 2006 | 12:37 PM
16vzetec's Avatar
16vzetec
you may want to keep the pas pump!!
i have complete mk5 zetec setup in my mk4 including alternator/ pas pump and brackets!
i have pas conversion
Old Oct 31, 2006 | 04:56 PM
xrmalin's Avatar
xrmalin
Cheers for all your input so far people,how do i go about blanking off the the power stering pump as i dont think ill bother putting it in ?
ps there is probabley another gear inside the casing thus reversing the drive of the pas pump just a suggestion though as ive never taken apart.
Old Oct 31, 2006 | 10:27 PM
Wardy257's Avatar
Wardy257
It is the extra pulley of the PAS pump that means that when the belt hits the waterpump it is going in the opposite directing. Hence, if you remove the PAS the belt will turn the waterpump the wrong way.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
