deflex bushs (help)
Old Oct 26, 2006 | 05:50 PM
rsvan's Avatar
rsvan
Default deflex bushs (help)
done most of them on my 2wd cossie but dont no where these ones go
theyve got sr 8-a stamped on them
many thanks in advance
Old Oct 26, 2006 | 06:06 PM
rsvan's Avatar
rsvan
Old Oct 26, 2006 | 06:35 PM
boost mad's Avatar
boost mad
not 100% sure but could be rear beam bushes
Old Oct 26, 2006 | 06:44 PM
Chris and Dawn's Avatar
Chris and Dawn
Are they not part of the rear beam mounting bushes.
They are two piece iirc.
Chris
Old Oct 26, 2006 | 06:57 PM
cos jon's Avatar
cos jon
These sit directly above the other beam bushes otherwise your beam rubs on the chassis.
Old Oct 26, 2006 | 08:09 PM
CosKev3's Avatar
CosKev3
As above,deffo rear beam bushes
But,I think they go between the plate that you bolt up to chassis and beam.
If you look at the shaped/cut out shape on the bush pictured above it matches the raised part of the plate that bolts upto beam
Heres mine:
Old Oct 26, 2006 | 08:33 PM
Chris and Dawn
Yeh thats how i fitted mine.
Old Oct 26, 2006 | 09:51 PM
rsvan's Avatar
rsvan
oh shit
Old Oct 26, 2006 | 09:55 PM
Chris and Dawn
Old Oct 26, 2006 | 09:57 PM
rsvan's Avatar
rsvan
please tell me that its just 2 17mm and 1 19mm bolts i need to undo
Old Oct 26, 2006 | 10:00 PM
Chris and Dawn
Yes it is.
Have you just put the larger bush in on its own?
Old Oct 26, 2006 | 10:14 PM
rsvan's Avatar
rsvan
ye, took it for a drive and it was shuddering at 80
Old Oct 26, 2006 | 10:19 PM
Chris and Dawn
The long 19mm bolt won't pull the beam tight without the small bush in place.
Chris
Old Oct 27, 2006 | 02:34 PM
cos jon's Avatar
cos jon
how odd, deflex told me to fit it the other way !!!
cos kev,
I notice you have only 8,8 grade bolts for your rear arms these should be 10,9 !!
Old Oct 28, 2006 | 12:31 PM
RS beddy's Avatar
RS beddy
i though they where off the bump stops on the cones that the springs sit around that is where mine went. when i got the full back end kit
Old Oct 28, 2006 | 03:28 PM
cossie604's Avatar
cossie604
Originally Posted by CosKev3
Heres mine:
Mine are fitted up the same as Coskev3 I figured that the extra bush acts a bit like the old alloy supports you could buy to try and calm down the beams antics of bouncing all over the place under hard acceleration...so I fitted them in the same way.
Old Oct 28, 2006 | 09:31 PM
CosKev3's Avatar
CosKev3
Are you running the car with the bushes fitted like that?????
Hope you didn't leave the spring bushes in the trailing arms like on the pic!!!!!!!!!
Positive the way mine are fitted is right
Mainly cause of the shaped bit cut out where the plate sits
Old Oct 29, 2006 | 02:48 PM
cos jon's Avatar
cos jon
Does anyone know how these should be fitted as Deflex told me that the extra bush sits on the top of the beam mounted bush not below !!
Old Oct 30, 2006 | 10:14 AM
CosKev3's Avatar
CosKev3
Pretty sure mine are right
The bush is shaped the same as the plate that bolts the beam up,so looks obvious to me
Also there are raised round bumps on the top of the main beam bush,which IMO go up against the chassis
Look how the original bushes are fitted,the biggest part of the bush is at the bottom of the beam,so thats how the Deflex ones should be IMO
Old Oct 31, 2006 | 06:53 PM
cos jon's Avatar
cos jon
I must admit i thought that about the raised bits when i first saw them, well off it comes again !!!
Old Nov 1, 2006 | 09:46 AM
CosKev3's Avatar
CosKev3
OH dear
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
