tuning an rc petrol car
Old Oct 26, 2006 | 03:21 PM
b_kennedy's Avatar
b_kennedy
Default tuning an rc petrol car
Hi. I got a thunder tiger car that I have just taken apart and fitted a 2 speed box. Unfortunately the settings aren't right and the engine keeps cutting out. Anyone know how to adjust the fuel and airscrews.
What the settings are should I say or how to find out. thanks
Old Oct 26, 2006 | 03:31 PM
ballin's Avatar
ballin
look on google mate theres tons of info.
www.rcnitro.com
or
www.nitrorc.com
used to have good tech guides, that was a few years ago now though!
Old Oct 26, 2006 | 03:32 PM
b_kennedy's Avatar
b_kennedy
thanks fella. didnt think of that
Old Oct 26, 2006 | 03:33 PM
vroomtshh's Avatar
vroomtshh
Best to make sure you start off on the rich side. Easy enough to lean it out
Old Oct 26, 2006 | 05:24 PM
mcrmatt1983's Avatar
mcrmatt1983
It might be your new gearbox thats causing some of the problem.
That has a adjustable grub screw inside it that adjusts the gear change-over, if thats not set up properly it doesn't let your engine run too well.
Old Oct 26, 2006 | 05:49 PM
smithy20vt's Avatar
smithy20vt
I have the same problem on mine will randomly cut out when coming off throttle have spent ages sorting out servos and linkages but still not working
Old Oct 26, 2006 | 07:36 PM
b_kennedy's Avatar
b_kennedy
smithy20vt
Have you got a HPI?
Old Oct 26, 2006 | 10:28 PM
MB7201's Avatar
MB7201
Usually I think the start settings is about 1.5 turns out from main needle. Then basically once warms start from there and test it out, and turn it out 1/4 of a turn and test out, 1/4 turn and test out etc, and then find the point where the engine runs best and the 1/4 turn added gives no performance gain. When you find this point turn it in 1/4 of a turn again to the last place.
If that doesn't work could be the carb needs cleaning. If the shift point is also set quite low so then it goes straight into 2nd gear, it could be straining the engine. Check the shift point first then mixture
Old Oct 27, 2006 | 10:44 AM
b_kennedy's Avatar
b_kennedy
Thanks for that advice. I gotta charge the glow plug again now then I'll give it ago
big_Rad
Sep 15, 2017 09:36 AM
malkiemac3579
Jul 14, 2017 12:10 PM
Roosie
27
Aug 19, 2015 12:16 AM
RUBY123
Aug 14, 2015 09:26 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
