Sapphire stage 1 chip
Old Oct 26, 2006 | 09:42 AM
Paulo P's Avatar
Paulo P
Default Sapphire stage 1 chip
I've just received my superchips stage 1 chip but I have some questions
What exactly does a stage 1 chip do? Is it a remap for fuel, boost and ignition timing or does it simply raise the boost limit?
To install it what do I need in other parts? Do I need a new actuator? Do you adjust the fuel reg? Or simply plug it in?
Thanks
Old Oct 26, 2006 | 09:50 AM
STUCOS's Avatar
STUCOS
Morning paul, -31 actuator require,plug in chip,fit actuator,turn up boost.check boost with guage whilst driving in 3rd gear under load,also get fuel pressure checked,should be 3.5 bar at tickover with vacum pipe off of regulator
cheeRS stu
Old Oct 26, 2006 | 09:52 AM
Paulo P's Avatar
Paulo P
Morning Stu.
That's what I thought but what do you know about the chip itself?
I'll source an actuator and get a mate to help set it up and check for det
Thanks
Old Oct 26, 2006 | 12:20 PM
STUCOS's Avatar
STUCOS
Paul did you buy chip new,if so wasnt there any fitting instructions with it,if not i would say 17 psi of boost would be safe
cheeRS stu
Old Oct 26, 2006 | 12:36 PM
Paulo P's Avatar
Paulo P
I bought it off ebay second hand. No destructions with it so I'm trying to source an actuator
Old Oct 26, 2006 | 12:39 PM
STUCOS's Avatar
STUCOS
Paul phone prima racing on 01159491903 i know they are a super chips dealer,if you can speak to tony or neil they should keep you right
cheeRS stu
Old Oct 26, 2006 | 01:06 PM
Paulo P's Avatar
Paulo P
Thanks
Old Oct 26, 2006 | 03:27 PM
mark taylor's Avatar
mark taylor
Default chip
SET YOUR BOOST TO 15 PSI MAX AS YOU ONLY HAVE A STANDARD MAP SENSOR [ THAT WILL BE THE LIMIT OF THE STANDARD SENSOR 14.7]
PLUG IN NEW CHIP WITH CUT OUT ON CHIP MATCHING CUT OUT ON BOARD.
SHORTEN ACTUATOR ROD ONE FULL TURN AND TEST IF STILL NOT ENOUGH BOOST SHORTEN IT HALF TURN AT A TIME TILL PEAKS AT 15 PSI.CHEERS MARK
Old Oct 26, 2006 | 05:12 PM
Paulo P's Avatar
Paulo P
First I need to get the headlights working and find an actuator then I'll do it. The headlights are my main priority
Thanks for the advice
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Fil
Sep 30, 2015 12:08 PM
