saph cossy speakers???
Old Oct 25, 2006 | 06:31 PM
r5200bhp's Avatar
r5200bhp
Default saph cossy speakers???
am i rite in thinking that the size for front door speakers are 5.25 or 5 1/4 inch??? dont want to get the wrong size.
Old Oct 25, 2006 | 10:15 PM
r5200bhp's Avatar
r5200bhp
nobody know
Old Oct 25, 2006 | 10:31 PM
JjCoDeX75's Avatar
JjCoDeX75
Yup, they are 5 1/4 inch - at least I have fitted them to mine.
Be careful, though some of the modern speakers are very very thick.
I use Infinity Perfects 5.1's - stunning sounds, but the cone moves so much, I had to use the spacer bracket to hold the door card out of the way
JJ
JjCoDeX75's Avatar
JjCoDeX75
The plastic speaker brackets are readily available in scrappers on any sierra, so if modification is required, then get a spare set ifyou are worried (i wouldnt be)
Old Oct 25, 2006 | 10:40 PM
phil4x4saph's Avatar
phil4x4saph
I'm pretty sure I could only get 4" in the front doors.
That was without modifying the bracket though.
Was a cheap Sony set as a temporary measure about 18 months ago!
Will get me some infinity's one day!
Old Oct 26, 2006 | 07:48 AM
gingeRS's Avatar
gingeRS
someone once mentioned to me to get the vauxhall corsa speaker adaptor rings to fit 5 1/4 to a saff.
apparently they go under the door cards no probs, but there are issues with speaker depth.
Old Oct 26, 2006 | 08:12 AM
Cawood's Avatar
Cawood
Default Re: saph cossy speakers???
int 5.25 n 5 1/4 the same size?
i wanna upgrade my speakers as well now, what size are the rears?
Old Oct 26, 2006 | 09:49 AM
JjCoDeX75's Avatar
JjCoDeX75
I absolutely guarantee that 5 1/4 speakers can be made to fit in the front door pods. Must admit that I drilled new pilot holes in the bracket for mine, but it is worth it. 4" speakers are just too small
JJ
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
