Ignition timing PLEASE HELP.
Old Oct 25, 2006 | 06:01 PM
Default Ignition timing PLEASE HELP.
..just timed the car up...now i always thought the ignition timing mark was the half moon mark on the block and put the pointer in the middle and that then lones up with the mark on the dizzy body...now my home built engine does just that...this one when the dizzy mark is lined up with the rotor the pulley pointer is more anti clockwise...aim i timed uyp ok and what would happen if its wrong?...(all cam timing is spot on)..It fires up and runs lovely..bit rattley to start but is now virtually rattle free a good run will sort it (new followers in)
Old Oct 25, 2006 | 06:06 PM
xr4x4rs's Avatar
xr4x4rs
the way i looked at the dizzy when i timed mine up was take teh cap off and the rotor arm will point to a dot inside the dizzy and the arrow on the pulley points at roughly 1-2 oclock
Old Oct 25, 2006 | 06:18 PM
..well it does that on this engine
..just need symtoms in case i got it wrong?
Old Oct 25, 2006 | 06:22 PM
xr4x4rs's Avatar
xr4x4rs
it will run like a bag of shit if the timing wrongs surely
Old Oct 25, 2006 | 06:29 PM
...must be ok then
Old Oct 25, 2006 | 06:36 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Bosch man: just make sure that the rotor is on the dot when timing
And yes, it WILL run like SH** it its not timed correctly, it will either knock or loose power
Old Oct 25, 2006 | 07:28 PM
ECU Monitor Enthusiast
Just for future reference....
The Distributor does NOT affect ignition timing or injection start point.
It is only used to tell the ecu which "PHASE" it is on.
I.E. Which injector to fire next and also obviously which spark plug is next.
The crank sensor controls ALL timing.
Old Oct 25, 2006 | 10:38 PM
Cheers Simon
Old Oct 26, 2006 | 12:37 AM
lke cossiemanden says, just make sure the dot it lined up and your phase sensor will be fine
Old Oct 26, 2006 | 08:21 AM
foreigneRS's Avatar
foreigneRS
Testing the future
omg i can't believe that you've been tuning cossies all this time and didn't know that the distributor only does just that - distributes the spark to the correct cylinder - and has no influence on the timing of it (except the function of the phase sensor) (that's the nearest smilie that we have for a cowboy)
Old Oct 26, 2006 | 09:31 AM
..thats DIY baby.
....BUT you then go on to say phase sensor so if i had timed it like my other engine it would infact be out?..
Old Oct 26, 2006 | 09:34 AM
Originally Posted by Keith Duckworth
Its better to be uninformed than to be ill informed
Old Oct 26, 2006 | 10:22 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Originally Posted by Bosch-Man
..thats DIY baby.
NO - the phase sensor does nothing with the actual timing (in terms of advance or, perhaps more appropriately in your case, retard). it just tells the ecu which phase the engine is in as a crank position sensor cannot do that alone (as it is a 4 stroke cycle that has 2 crank revolutions per cycle).
Old Oct 26, 2006 | 10:30 AM
Stu @ M Developments's Avatar
PassionFords Creator
Classical.
Old Oct 26, 2006 | 10:31 AM
..now your just getting technical..which i dont really need to know ...i asked a question to be safe...nowt wrong in that no matter how retarded the brain boxes think it is...not all are well educated..in my case NOT educated
I think if Chip carries on as he is i may be his mate ..you gotta make allowances for dumbo's instead of taking the piss like you Foriegn geezer and the old Chip...but i doubt it will last ..
Old Oct 26, 2006 | 11:05 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i can't help it phil, you set yourself up for it it's all lighthearted humour
if you were new on the board, or new to cossies, i would have a different attitude and be more helpful without the sarcasm and piss taking, but you've always blown your own trumpet about how good you are at diy tuning so i see you as a target.
you just worry me slightly that you do a lot of fiddling about with things like fuel quality retard jumpers that do affect the spark timing, yet you don't seem to know the basics of how your engine management system works. i would also recomend to you that you read dave walkers book on efi to get a good grasp of the basics, as by your own admission you are not technically profficient.
Old Oct 26, 2006 | 11:25 AM
Oh i see no worries.....the bridge on the timing shouldnt have been on there..it was MAD thing as it was a 7.4-1 engine on a ahmed 7.2-1 map so had to take ignition out...Obviously my NMS map was for 7.4-1 hence no need to have that bridge..and the way it now feels is so much better!
I have made many mistakes building and cam timing etc...ask Stu and Mark ...but imlearn as i go..i wont read books..LOL...cant be bothered.
Old Oct 26, 2006 | 12:32 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Phil,
Have you checked for Det since removingthe bridge and putting the ignition back in?
Old Oct 26, 2006 | 12:38 PM
The map was designed not to have that bridge and was 100% safe according to Karl...but i will check when i start holding it flat...but may be hard as i shit my self when it comes on boost especially in 3rd
Old Oct 26, 2006 | 12:41 PM
CossieRich's Avatar
CossieRich
Phil,
My chip done by Stu is also 100% safe but a crack of det in 4th gear at high boost meant Mark had to use the octane switch to restard the ignition. Since i have been using V-power though we have put the ignition back in Make sure you deffo do a det check mate
Old Oct 26, 2006 | 12:42 PM
foreigneRS's Avatar
foreigneRS
Testing the future
hold it against the brakes
Old Oct 26, 2006 | 12:44 PM
...i am only running V-MAX and Karl took ignition out to prevent any cock ups .....Now you see how retarded i was/am
Old Oct 26, 2006 | 12:45 PM
CossieRich's Avatar
CossieRich
Good idea Nick, let the engine come under load whilst holding the car back on the brakes
Old Oct 26, 2006 | 12:54 PM
I get people to do that when they are driving and im mapping, was a tip from Stu@MSD
Old Oct 26, 2006 | 01:01 PM
..i always found it hard to do this with 450 + horses
Old Oct 26, 2006 | 01:02 PM
foreigneRS's Avatar
foreigneRS
Testing the future
not good for the brakes for too long, and can be dodgy in a rwd as the rears can spin up
Old Oct 26, 2006 | 01:20 PM
The brakes are ok as an "assist", but you cant beat using a nice hill and 4th gear as well
I like mapping in 5th, but the mrs license doesnt
Old Oct 26, 2006 | 01:35 PM
foreigneRS's Avatar
foreigneRS
Testing the future
tricky to find in norfolk
Old Oct 26, 2006 | 01:38 PM
you would have norfolking chance at all i should think
Old Oct 26, 2006 | 01:41 PM
CossieRich's Avatar
CossieRich
Mark was doing it in 2nd gear on mine, trying to listen for any boost leaks. Was great when he came off the brake. 33 psi straight through the rear wheels.
Old Oct 26, 2006 | 01:42 PM
Rich. what you felt then (the sudden rush of extra power without a slow turbo style build up) is what you get with nitrous
Old Oct 26, 2006 | 01:44 PM
CossieRich's Avatar
CossieRich
Really? Excellent Is a good feeling wouldnt you agree Chip
Old Oct 26, 2006 | 01:51 PM
I like both, i kind of enjoy the way a turbo surges the power in, but instant hit is cool too
big power N/A is also similar "just took my foot off the break" delivery too.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
PaulinhoT
Oct 28, 2015 06:06 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
