FAO Bosch_man (or anyone else who might know)
Old Oct 25, 2006 | 03:24 PM
Default FAO Bosch_man (or anyone else who might know)
Got a flow rate listed for injector:
0-280-156-280
(also says 957 on the bit where the elitrical connector plug goes and 681 on the body)
Old Oct 26, 2006 | 10:34 AM
Btt
Old Oct 26, 2006 | 10:35 AM
Garage19's Avatar
Garage19
I've looked, but its not listed on any of the info i have.
WTF is it out of?
Old Oct 26, 2006 | 10:40 AM
Astra VXR
Likewise i cant find it anywhere else, but thought Phil might have access to data that the likes of us and google dont, lol
Old Oct 26, 2006 | 10:53 AM
No go on that number main dealer (vauxhall) only part so cant get any info sorry
Old Oct 26, 2006 | 11:02 AM
No worries, thanks for looking
Old Oct 26, 2006 | 11:04 AM
Garage19's Avatar
Garage19
Time to build a flow bench!
Pretty simple really if you have a spare fuel rail/reg and some measuring cylinders.
Could use a simple circuit with a maplins timer.
Old Oct 26, 2006 | 11:10 AM
Not a bad idea that, but as ive already bought them, im going to put them in the car and see if the ECU can manage to learn them or not.
They are rumoured to be rated at 475cc, and ive seen the ecu learn upto 440cc, so should be ok hopefully.
Will have wideband on it all the time initially while its trying to learn them, so will see how it gets on i guess!
I know they are at least big enough for what i want (just over 300bhp), Im just worried they might be too big!
Old Oct 26, 2006 | 11:12 AM
Chip..why worry about being too big?...I have 1000cc's in and get 3.5% co tickover on L8 or is your ECU more basic?
Old Oct 26, 2006 | 11:17 AM
Sorry Phil, i didnt really give a lot of detail there mate.
Basically this is for my girlfriends car, which is a calibra turbo.
The ecu in it is actually far from more basic than an L8, its actually really quite clever, its "adaptive"
It looks at the corrections it is making during closed loop fuelling and uses them to alter its own internal injector scaling tables, so that if you fit bigger injectors, it "learns" them.
But there is a limit to how far it can adjust like this, and if you put an injector in that is too big, it wont be able to get the fuelling lean enough.
Obvioulsy a live map or new chip would sort this, but there are VERY few people who have the equipment to do that on this ECU (motronic 2.7, might even be the same as in your 348 as i know they are used in some ferraris of that era) so i was hoping to get away with an "off the shelf" chip if possible just becaues of the hassle/expense of her having to take it up to Stu.
Old Oct 26, 2006 | 11:22 AM
My 348 runs 2 ECU's one for each bank...i have receipts to say its be chipped to take into account k&n filter element and decat sports exhaust..although i did here it self learns....
Old Oct 26, 2006 | 11:28 AM
Very probably its the same system then
Still needs chipping for changes to the timing, its only the fuel it copes with (to a point) via the self learning
She has a chip anyway, but its intended for the standard injectors with the pressure wound up, which equates to about 400cc ish
Is yours on AFM or MAP?
Old Oct 26, 2006 | 11:30 AM
Has 2 x air mass sensors
Old Oct 26, 2006 | 11:34 AM
Gotta be the ulimate for "get you home" reliability then, even if one half of the engine dies on its arse you can still drive home on the other half
Old Oct 26, 2006 | 11:36 AM
...yep...and you need it ..My mate said it sounded like 2 engines on tickover..bizarre...i think the 355 went to one ECU and there on.
Old Oct 26, 2006 | 11:37 AM
355 on tickover sounds like someone shaking a can of nails
Doug had his idling at weston for a while before he went out, to warm it up, and everyone thought it was fucked. LOL
At least it proved it wasnt an Mr2, they purr like a kitten on tickover.
Old Oct 26, 2006 | 11:40 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
My god,
Was that actually a decent convo between Chip and Phil. Well done guys
Old Oct 26, 2006 | 11:45 AM
Garage19's Avatar
Garage19
That will be the flat plane crank. Fires like two four cylinder engines rather than a conventional V8.
Old Oct 26, 2006 | 11:46 AM
Originally Posted by CossieRich
My god,
Why the surprise?
We're all grown up DIYers here, not like you and Mike with your "my tuner is better than your tuner" nonsense
Old Oct 26, 2006 | 11:48 AM
CossieRich's Avatar
CossieRich
My god,
Why the surprise?
rofl DIYers yes. grown up im not so sure about. I never said my tuner is better than Mikes. I leave that for Rod to say
Old Oct 26, 2006 | 11:50 AM
My god,
Why the surprise?
Its so wrong getting your grandad to fight your battles for you
Old Oct 26, 2006 | 11:51 AM
My god,
Why the surprise?
Old Oct 26, 2006 | 11:53 AM
CossieRich's Avatar
CossieRich
My god,
Why the surprise?
lol
Old Oct 26, 2006 | 11:56 AM
Disabled Account's Avatar
Disabled Account
Phil, the 355's have TWO ecu's (both fitted to the inner bulkhead panel behind the seats)...and these ECU cases look exactly the same as L8 / P8....they have the same cast chassis with pressed alliminium lids/pozi screws.....just different Webber stickers.
Old Oct 26, 2006 | 11:59 AM
Sounds like they took a step backward then Doug if they went from an ECU with self learning etc to a shonky old L8!
Old Oct 26, 2006 | 12:00 PM
...oh ok i thought the 355 went to 1 ecu..maybe the later ones did?
Old Oct 26, 2006 | 12:04 PM
Disabled Account
Mine was a 1998 car.......and they only made them until 1999.
Chip, I'm not saying that an L8 / P8 was fitted to the 355's, only that the case/chassis & mult-pin connector was the same.
Also, I'm sure they were closed loop, I did notice 4 x Lamda sensors (2 per bank).
Oh, and PINK Bosch injectors were fitted
Old Oct 26, 2006 | 12:10 PM
Interesting stuff, you should have got stu or karl to live map it
Mine also look L8 lol
The F40 run a pair of P8's and the Ducati 916sp run a P8 too
Old Oct 26, 2006 | 12:11 PM
Pink?
:gayflag:
Old Oct 26, 2006 | 12:13 PM
...also mine has 2 lambda bungs...it has about 0.8co at idle.
Old Oct 31, 2006 | 08:34 AM
Graham S1's Avatar
Graham S1
My god,
Why the surprise?
chip has me to pick on at the moment.
Old Oct 31, 2006 | 09:01 AM
Graham, this post is 5 days old, or did you open it in your research to try and find where elvis lives now?
MikeyRobbo
Jan 29, 2012 07:03 PM
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
