Low C/R = higher torque in general ?
Old Oct 25, 2006 | 01:51 PM
leecavturbo's Avatar
leecavturbo
Default Low C/R = higher torque in general ?
Just got the car back on the road after Lowering C/R feels more torquey.
Obviously the main reason for me lowering is to allow more boost, but i remember years ago having massively reduced C/r seemed to give better low end feel (more torque) ?
Discuss
Old Oct 25, 2006 | 01:53 PM
The correct CR will give the most torque.
any lower an you get less torque (cause PCPs are too low)
any higher and you get less torque (cause PCP's arrive too late)
Old Oct 25, 2006 | 02:00 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
how do you work out the correct c/r?
can of worms time
Old Oct 25, 2006 | 02:10 PM
AlexF's Avatar
AlexF
engine testing will tell you whats best!
Old Oct 25, 2006 | 02:42 PM
can of worms time
It increases as RPM increases
Old Oct 25, 2006 | 02:46 PM
AlexF's Avatar
AlexF
you sure about that chip?
It increase as cam duration increses......
Alex
Old Oct 25, 2006 | 02:47 PM
Alex
It decreases as boost increases
Old Oct 25, 2006 | 02:48 PM
GARETH T's Avatar
GARETH T
the only way is to test
Old Oct 25, 2006 | 02:51 PM
Lots of true statements in this thread.
Complicated business Lee
Old Oct 25, 2006 | 02:53 PM
AlexF's Avatar
AlexF
Torque is a function of cylinder pressure and the throw of you crankshaft.
So the lower the comp typically the worse the engine performance off boost.
Hence many manfuactures using high CR and LOW boost so that the engine remains torquey at the low end and retains fuel economy.
Alex
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
