CVH head casting for big valves
Old Oct 25, 2006 | 06:39 AM
Maki's Avatar
Maki
Default CVH head casting for big valves
Read pumaracing artical on CVH head... it says that 81SM6090 casting would be fine for big valves, but also it says that there are two tipes...
"The cross-hatch casting has a ribbed cross-hatch pattern on the external sides and has thicker port walls and a better port shape. Only the cross-hatch casting can be used for 45mm valves."
Anyone got a picture or could explain this in other words?
I have 81SM6090 from 86'XR3 and D85SM6090 from 88'RST (the one isn't even mentioned in pumaracing)
Old Oct 25, 2006 | 09:45 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
If you look at the head where the inlet manifold meets the head surface.
You will either see a cross hatch patteren in the alloy, or it will be smooth casting.
Old Oct 25, 2006 | 09:48 AM
Versus_Creations
Ask me a question!
Just to add that most EFi heads are perfect for the larger valves, as there is more material to be able to take away when porting and using bigger valves etc..
Also an EFi head will be worth more money once bigger this and bigger that are fitted as more poeple could use it after your finished.
EFi head can be used with either MFi management or EFi like weber, pectel etc..
HTH
Regards
Old Oct 25, 2006 | 09:59 AM
Maki's Avatar
Maki
Thats what I was thinking too... as I wish to go EFI in future... so will look for 89SM6090 EFI head... are there any other numbers that I could look for? (seen on the quantums page the head had D91SM6090 code on it)
P.S. you say Efi head will accept MFI manifold?
Old Oct 26, 2006 | 07:07 AM
Maki's Avatar
Maki
Up
Anyone know? Will MFI manifold fit EFI head?
Old Oct 26, 2006 | 09:43 AM
Versus_Creations
Ask me a question!
Yes an MFi Inlet will fit an EFi Head with a conversion plate i offer.
Regards
Old Oct 26, 2006 | 10:04 AM
Maki's Avatar
Maki
Regards
Ahhh, thats the same story like with MFI head and EFI manifold
Thats bad ... as for now I haven't got the money for all the EFI bits and map So will have to stay on MFI head I guess.....and later use adaper plate for EFI inlet
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
mrknifey
Aug 30, 2015 11:48 AM
Blown Hell
Aug 5, 2015 07:22 AM
