Opel C20XE pistons onto 2.0 zetec rods?
Old Oct 24, 2006 | 07:01 AM
Maki's Avatar
Maki
Default Opel C20XE pistons onto 2.0 zetec rods?
Anyone done that? how?
Old Oct 24, 2006 | 05:11 PM
SafeChav's Avatar
SafeChav
Im sure one of the two/both have to be machined and modified as the holes for the gudgeon pin arent the same sizes.
Old Oct 24, 2006 | 11:15 PM
NEWTON's Avatar
NEWTON
yes you have to brass bush the zetec conrods,so you have fully floting little ends
Old Oct 25, 2006 | 05:15 AM
Maki's Avatar
Maki
zetec rods aren't that thick to fit brass bush i guess
Old Oct 25, 2006 | 12:48 PM
NEWTON's Avatar
NEWTON
so how do they do it then ive seen people of here have these piston fited to these rods
Old Oct 25, 2006 | 12:52 PM
Maki's Avatar
Maki
Here's an e-mail from one of the best tunners I know
"The pistons have to be machined to clear the wider small end of the Zetec
conrods, and the bore of the Zetec conrod has to be honed out slightly to
allow the XE pistons to be press fitted onto the XE piston pin."
Old Oct 25, 2006 | 02:27 PM
JesseT's Avatar
JesseT
Old zetec has a pin diameter of 20.63mm.
post -98 zetec has a pin diameter of 20.00mm
How about the XE?
Old Oct 26, 2006 | 05:09 AM
Maki's Avatar
Maki
Originally Posted by JesseT
How about the XE?
didn't measure, but they are thicker than zetec ones
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
