coolant / antifreeze question
Old Oct 23, 2006 | 04:36 PM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Default coolant / antifreeze question
Im going to be flushing and changing the cooling system in the sierra. So i went to ford to get some coolant/antifreeze. I picked it up and when i got home i had a good look at the bottle and noticed that it only says its antifreeze. So it looks like it has no antifreeze properties in it, is this right??
Usually i have bought an antifreeze and coolant mix.
Its called ford super plus premium antifreeze part number 1336799
Is this ok to run in my cossie?? or do i need to add coolant to it aswell??
Cheers Bruce
Old Oct 24, 2006 | 12:54 PM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
I think thats the right stuff, if you got it from fords it should be.
In a cossie you should run a 50/50 mix of water/antifreeze.
Old Oct 24, 2006 | 02:08 PM
broos3's Avatar
broos3
Kool mate, im sure it is!! Just checking
Bruce
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
