Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
cosworth bottom end
Old Oct 22, 2006 | 04:56 PM
peteh's Avatar
peteh
Default cosworth bottom end
what have you, 200 or 205 block, what you got
something that needs a rebuild or been stood.
pete
Old Oct 22, 2006 | 06:01 PM
D7AKE's Avatar
D7AKE
I have a 205 block if your interested how much are you looking to pay
You can pm me if you like
I would also be interested in swapping for cosworth bits
Si
Old Oct 22, 2006 | 06:53 PM
peteh's Avatar
peteh
just seeing how much people want for them mate
as ill need to buy crank, rods, pistons etc etc
Old Oct 23, 2006 | 01:55 PM
peteh's Avatar
peteh
anybody??
Old Oct 24, 2006 | 06:51 AM
D7AKE's Avatar
D7AKE
I would sell mine for Ł300 ono but it needs a piston mine comes with mounts flywheel clutch etc
Got to be worth that
Si
Old Oct 24, 2006 | 06:56 AM
peteh's Avatar
peteh
Si
pm more details mate is it a complete bottom end?
Old Oct 24, 2006 | 07:29 AM
fordnut's Avatar
fordnut
Default Bottom end
I have a complete 205 bottom end. Includes Crank, Rods, Pistons, oil pump, Sump, flywheel and bottom pulley.
Ran ok, has done 100k. Only thing missing are the 2 screw in water jacket bungs which went in my new engine.
Pm or email me if you are interested.
Old Oct 24, 2006 | 12:33 PM
turbodan's Avatar
turbodan
Ive got a bare 205 block on standard bore in good nick mate. pm if interested not after much just need it out the way
cheers
Dan
Old Oct 24, 2006 | 05:01 PM
D7AKE's Avatar
D7AKE
you have pm
Old Oct 25, 2006 | 06:35 PM
peteh's Avatar
peteh
any 200 blocked engines???
Old Oct 26, 2006 | 01:11 AM
jon@work's Avatar
jon@work
I've got a 0.5mm oversized 200 block with pistons - should hopefully be for sale next week when I get a new block. No lip at the top of the bore. Have also got a set of rods on the pistons and a 0.5mm (big ends and mains) undersized crank just polished, just needs bearings. Will all go up for sale only when I've got a new block. If you need them, can also do you a used 2wd oil pump (with the lid machined to remove the wear) and a 2wd pick-up pipe.
I bought the engine hoping it would be on a standard bore (came out of an 80k miles car), cause I've got some 0.25mm low comp Cosworth pistons that need a home, only to find it is 0.5mm over, so no good to me. If there turns out to be a problem sourcing a new block, I'll have to keep it and get it linered, which is why I can't sell it before I get a new block in my greasy little mits.
Old Jul 15, 2007 | 10:10 AM
peteh's Avatar
peteh
bttt, after one again
Old Jul 17, 2007 | 10:42 AM
peteh's Avatar
peteh
bttt
Old Jul 20, 2007 | 08:43 PM
peteh's Avatar
peteh
thanks to the people that have pm'd me, im looking for something abit closer though
thank you anyway
KW-rscos
11
Aug 31, 2015 01:51 PM
Bosch
Aug 23, 2015 12:31 PM
IAN RS2k
Aug 18, 2015 07:51 PM
john_3.0s
Aug 15, 2015 07:44 AM
Aug 14, 2015 07:29 AM
