what clutch are you running ??????????
what clutch / power / torque are you running???
i am struggling to put my 450 BHP and 542NM through my clutch
i run an AP 6 paddle kit, fine on the go
, but when i launch it hard i go nowhere fast
, even worse if i use the ALS
, thinking twin plates but cost a fortune!!!
has to be drivable, not an on / off switch
.i run an AP 6 paddle kit, fine on the go
, thinking twin plates but cost a fortune!!!has to be drivable, not an on / off switch
Originally Posted by AJC
try an alcon 6 with ap coover plate
580bhp 3 door my mate has uses that i thiink
https://passionford.com/forum/viewtopic.php?t=219596
and I would consider swapping to hydraulic clutch also.
https://passionford.com/forum/viewtopic.php?t=213730
Hydraulic it, and it shouldn't be an issue
Mine has 477bhp and 565Nm and Alcon 6-plate paddle clutches last 15,000 miles.....
.Mine has 477bhp and 565Nm and Alcon 6-plate paddle clutches last 15,000 miles.....
how will the hydraulic conversion stop it slipping under hard launch ?????
was thinking of this any how but cant see how it will help on that side of things
Because it will allow the clutch to properly engage / disengage.
The ratchet is shit at self adjusting, constantly drags and over-heats the clutch, causing it to slip / wear out.
