Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
blue lit dials
Old Oct 20, 2006 | 06:24 PM
jamesgti's Avatar
jamesgti
Default blue lit dials
hi everyone. i have got a escort gti and while i like the green when the dials are lit up i would prefer to have them lit up in plasma blue. i have been told that i can change the green bulb in the dash to a blue bulb. just wondering if anyone has done this.
Old Nov 13, 2006 | 11:44 AM
pwhitelock's Avatar
pwhitelock
You can do that or just use halfords bulb paint. Dip the bulb in and there you go. Iv seen it done on a ford cougar and they looked quite good. Just dont dip them too much as they appear a bit dull
Old Jan 8, 2007 | 07:28 PM
slickescort1981's Avatar
slickescort1981
as far as i know the bulbs are clear. only problem is that where the lights shine through onto the dials thers a green plastic strip on theplastic cover. If u could take this off then blue bulbs will work but i cheated. i took off the front cover and fitted a small blue neon inside but in front of the green piece. then took out old bulbs. pretty bright and looks great.
Old Jan 15, 2007 | 05:25 PM
gus's Avatar
gus
i relaced my bulbs with blue l.e.d's works well
no pics thou
Old Jan 15, 2007 | 06:56 PM
djmillsy's Avatar
djmillsy
Fife Radge
they do have a green plastic cover i took it off and had clear ones on it
Old Jan 30, 2007 | 08:43 PM
GazzaG's Avatar
GazzaG
gus
So did i
DAZZER
Sep 30, 2015 08:43 PM
