4x4 FMIC
Old Oct 20, 2006 | 04:04 PM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Default 4x4 FMIC
Im thinking of replacing my 2wd intercooler with a 4x4 item. Im in curretly striping my can and replacing some items and cleaning etc.
Would i see a difference in performance over with the 4x4 intercooler?? Or will it need to be mapped before gains are seen??
Also are they hard to fit?? I heard that its easy, just drill afew more mounting holes and thats that. Will I need new boost pipes to fit it??
thanks for any help
Bruce
Old Oct 20, 2006 | 04:56 PM
escort mk6's Avatar
escort mk6
youll need to cut the boost hoses down too from what i remember when i looked at fitting a 4x4 cooler to my 2wd
Old Oct 21, 2006 | 08:46 AM
broos3's Avatar
broos3
Ok mate.
Does this mean that the 4x4 cooler is deeper than the 2wd drive one?? Rather than being longer??
Just trying to get my head around the size of it.
Bruce
Old Oct 21, 2006 | 10:47 AM
Tarren's Avatar
Tarren
It will fit fine with good results i think the 4x4 cooler is 50% bigger overall
you will also have to bend down 2 metal tags on the top of the rad if it is 2wd rad but hopefully you will have the 4x4 rad that is a little shorter easy done with a set of plyers
Old Oct 21, 2006 | 06:22 PM
broos3's Avatar
broos3
OK mate thats kool. Sounds easy!! Just dont want to buy new boost hoses. Im sure its a 2wd rad, it looks like the original item, the cars only done 50k and only been used for 5 years so im sure its not been changed lol.
Bruce
Old Oct 21, 2006 | 06:34 PM
broos3's Avatar
broos3
Anything else needing changed when changing from a 2wd to a 4wd cooler???
Im sure plenty of you guys have done this.
Bruce
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
