Closed Loop and Coil Pack Conversion
Old Oct 19, 2006 | 08:28 PM
Daveesaunders's Avatar
Daveesaunders
Default Closed Loop and Coil Pack Conversion
I have an '89 2wd Saph and I am really interested in getting a closed loop system and a coil pack conversion fitted. My question is are both systems compatible with the ECU I have or do I need to change to a different one. I have seen several posts and several different ECU numbers flying around and it confused me as I haven't got the foggiest as to what ECU I have or what I need.
I've already had a boss welded on to the exhaust pipe and I have a lamda sensor fitted to run my AFR gauge (even though this seems to respond to the stereo more than the sensor)
Old Oct 19, 2006 | 08:36 PM
the original's Avatar
the original
coilpack can be done on your ecu by MSD
for closed loop fuelling i suggest you will be required to upgrade to at least a level 8 ecu
Old Oct 20, 2006 | 09:28 PM
costina's Avatar
costina
Live long and prosper!!
L8 you need for this conversion(closed loop) post a pic of yours up and we can tell you if yours has no mounting lugs and has a red or green sticker its poss a L8 (4x4 ecu)
your lambda has a bad earth if responding to your tunes,most lambdas will work post a pic up and we should b able to say...
you will need
L8 ecu + std babyboad
PF09 TPS sensor
Lambda sensor
MSD closed loop chip
Two ign amps
Loom
Coilpack (1.6 sierra cvh or similar)
Ign leads
ECU converted by MSD to run coilpacks
Hope this helps
Old Oct 21, 2006 | 12:24 PM
Daveesaunders
you will need
PF09 TPS sensor
Lambda sensor
Really helpfull cheers I was guessing the Lamda would have a bad earth just got to find some time to sort it out. Definatly have a standard 2wd ECU. Would the L8 one plug straight into the current loom or will I need to change it for another?
Two ign amps
Loom
Ign leads
Hope this helps
Old Oct 21, 2006 | 12:35 PM
costina's Avatar
costina
L8 will plug into loom you will need to put a wire to pin no2 for lambda signal and power from fuel pump relay to power lambda
then theres two wires for coilpack
its easy just follow instrutions with the kit..
Old Oct 21, 2006 | 02:51 PM
Daveesaunders
Wheres the best place to find an L8 ECU and roughly how much are they?
Old Oct 21, 2006 | 05:32 PM
BIL N KEL's Avatar
BIL N KEL
you will need
PF09 TPS sensor
Lambda sensor
Two ign amps
Loom
Ign leads
Hope this helps
is this all you need to go L8 as id like to convert my 2wd saff
Old Oct 21, 2006 | 05:48 PM
jon@work's Avatar
jon@work
To convert your saff to L8, all you need is a PF09 TPS, and change the outer 2 TPS wires. Obviously, you'll also need a suitable chip (different to L6 chip) in a L8 ECU on either the standard baby board, or a Pectel/Collins/whatever board. The rest of the kit listed above is for the coilpack conversion
Old Oct 21, 2006 | 09:03 PM
costina's Avatar
costina
They come up on here and ebay look to pay £150 to £200 BUT you will need a std baby board most have been changed to pectel boards to run Bayjoo chips etc,but you can sell those boards easy on ebay i sold my last stg 3 one for £75 cheap cos if you buy um there £300 +
Happy Hunting
Old Oct 22, 2006 | 02:00 PM
dazzle740's Avatar
dazzle740
Default Level 8ecu
hi there mate
have you tried Paul (North Yorkshire RS Spares) as that is where i got mine from a while back with standard baby board
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
