advice on these wheels
Old Aug 26, 2004 | 03:40 PM
the strut brace's Avatar
the strut brace
Default advice on these wheels
bought these wheels, they are ford fitment and have track tyres on, how do i tell what the offset is, and what should it be for a safcoz, one is slightly different style but the guy says they are the same its just the style that is slightly different,want to use them for croft but need to know if i need spacers etc
Old Aug 26, 2004 | 03:47 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
It normally says on the wheel. If you look in the area that is on the right hand spoke on the bottom photo, it normally gives size and ET.
Old Aug 26, 2004 | 03:51 PM
the strut brace
right it says 6j x 15 et15 what offsett does that mean and what should it be for a safcoz mike???
Old Aug 26, 2004 | 03:55 PM
cossymad's Avatar
cossymad
No that is not.
Also one looks different to the others....ie different offset
Old Aug 26, 2004 | 04:00 PM
cossymad's Avatar
cossymad
Check all the offsets on ALL the wheels before parting with cash.
Take them to a tyre fitter and get them balanced.
They 'll go on if they are 4x108 et 35 but stick out a little bit further than the normal sierra ones.
Check the centre bore is 63.4mm other wise they could be peugeot ones
Old Aug 26, 2004 | 04:11 PM
the strut brace
all the wheels have 6j x 15 et 15 on them , so are they ok and whats this 4 x 108 et 35 your on about, the one thats different is a slightly dished wheel wheres the others are flat but the guy says they are the same offset and will be ok, how do i check the offsett if the numbers i have found are not the ones i need???
Old Aug 26, 2004 | 04:25 PM
cossymad's Avatar
cossymad
4= number of holes
108= distance between the holes in mm i.e. 108mm apart from centre of hole to centre of hole opposite on 4 stud
63.4== the centre bore of the wheel on the mounting face.
ET is the offset which is the distance from the vertical centre lineof the wheel to the surface of the wheel mounting face measured in mm
The smaller the offset the further apart the wheels ie et15 will stick out away from car and et 35 will be 20mm inwards- ideally where a sierra should be.
You can obviously fit the et 15 on but it will widen the track and may upset the handling and where tyres prematurely
Also the important is to measure the centre bore . If it is bigger than 63.4mm then the wheel will 'float' and not locate properly. If it is to small the wheel will not sit flush to the hub
Old Aug 26, 2004 | 04:29 PM
the strut brace
aaaah, now i see, thanks m8.
Old Aug 26, 2004 | 04:34 PM
RichardPON's Avatar
RichardPON
Also, ET15 are gonna stick out about an inch outside the arch!
Old Aug 26, 2004 | 04:40 PM
the strut brace
hows that if the offset is only 20mm different??? , fukin confused
Mike Rainbird
Caraholic
Just to clarify - COMPLETELY THE WRONG OFFSET - you've been shafted .
6 x 15 is smaller than the standard wheels . Were they off a Pug 205 or some such?
Old Aug 26, 2004 | 04:42 PM
RichardPON's Avatar
RichardPON
My guess is Escort Cossie rally car..............
Old Aug 26, 2004 | 04:45 PM
Mike Rainbird
Caraholic
Could be , they do use silly minute wheels for snow / gravel tyres....
Old Aug 26, 2004 | 04:50 PM
cossymad's Avatar
cossymad
Snow tyres / wheels would be ET 5 on 6j rim
Either way as Mike said (he likes the word shafted)
Try them anyway.
Pon was exagerating as usual....remember his 6'' cock turned out to be 2'' (according to his missus) & (Mike)
Old Aug 26, 2004 | 04:53 PM
the strut brace
they were off a fiesta wide arch rally car, the rims are mint and the tyres are ok but seeing as they are wrong, dont really matter so theres nowt i can do with them, e bay here i come
RichardPON's Avatar
RichardPON
Really Chris.
So the ET15 wheels I had didn't stick outside the arch nearly an inch then
Or the Compomotive rally wheels I sold off of my car weren't 6jx15 ET25
Old Aug 26, 2004 | 04:57 PM
cossymad's Avatar
cossymad
About an inch or nearly an inch ????
and did I say compomotive did n't sell et 25'' wheels that were on your saff??
Any way I think we are ALL right
Old Aug 26, 2004 | 04:58 PM
RichardPON's Avatar
RichardPON
Nope.
You're wrong.
On so many levels
Old Aug 26, 2004 | 07:10 PM
the strut brace
well, went out and had a go and they went on and dont seem to be a problem, havnt drove it yet but the tyres are really bulbous so might need to adjust the arches a little, but not much, so just goes to show ya never know
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
hopper350
Sep 4, 2015 12:53 AM
kevin36
Sep 2, 2015 06:24 PM
