air fuel ratio
Oct 19, 2006 | 05:16 AM
air fuel ratio
CAN ANYONE TELL ME WHAT THE CORRECT AIR FUEL RATIO IS FOR A STAGE 3 COSSIE 4X4, 803S 3 BAR,ETC.
Oct 22, 2006 | 08:18 PM
Hi,
Good AFR is 6% CO = 12 / 1
Ratio CO/AFR
Regards
Claude
Oct 22, 2006 | 09:55 PM
i would say around the 12 mark or 80-82 lambda
Oct 23, 2006 | 01:46 AM
Quote:
Originally Posted by 2001ode
Hi,
Ratio CO/AFR
Regards
Claude
Hi Claude, thank you for the info, what is the first column "V" for?
Oct 23, 2006 | 01:48 AM
Quote:
Thanks for the info, I am just about to fit an AEM AFR meter
Oct 23, 2006 | 06:34 AM
Hi,
Column V is "Voltage" of your narrow Lambda sensor.
Regards
Claude
Oct 23, 2006 | 08:40 PM
so does anyone know what 0,8% lambda (I think they called it like that )is in afr numbers ???
According to them it should be the reading when going on full throttle with my stage 3 setup on my Sapphire Cosworth....
Oct 23, 2006 | 09:29 PM
do you mean 0.80 lambda if so thats good for full boost
Oct 23, 2006 | 09:58 PM
That could be...how much will that be in afr numbers, as I have installed a WB AFR gauge and I dont know what to expect ....???
Oct 23, 2006 | 10:18 PM
what wide band is it does it read in afr or lambda
Oct 24, 2006 | 03:09 PM
It reads afr, and it is a wideband commander kit from Dynojet.
Oct 24, 2006 | 06:01 PM
around the 12 afr witch is 80-81 lambda witch is good for full boost but you will have to make shore that its not pinking
Oct 24, 2006 | 07:23 PM
Ok and thanks......
About "pinking" .... how would be the easy way to check it ???
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
markk
Sep 9, 2015 08:11 AM
