Water pump......
Oct 18, 2006 | 05:46 PM
Water pump......
Does the s1 water pump fit a s2 block???
Oct 18, 2006 | 06:11 PM
iirc they are slightly different
Oct 18, 2006 | 06:28 PM
yeah, noticed that s2 got one outlet and s1 got two, but will a s1 water pump bolt on 2 a s2 block???
Oct 18, 2006 | 06:37 PM
Physically it will fit yes
Oct 18, 2006 | 07:10 PM
cheers mate..... just that mite be buying a s2 block 4 my s1.....
Oct 18, 2006 | 07:16 PM
yea they do. The s2 design is better i think, you'd need to change a couple of pipes
Oct 18, 2006 | 07:34 PM
Ive got an S2 pump/block in my S1, altho that offers no real help to your question
altho iirc they are interchangeable to the block itself
Oct 18, 2006 | 07:48 PM
Thanks, just helps me not changing the hoses......
Oct 18, 2006 | 07:54 PM
If using the S2 pump, then one must use the S2 alternator carrier too.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
