Lambda sensor
Old Oct 18, 2006 | 10:58 AM
MazakMan's Avatar
MazakMan
Default Lambda sensor
Hi,
When fitting an air/fuel ratio meter to a car that previously never had a lambda sensor does it matter what the sensor comes from or will literally any lambda sensor do?
Also where is the best place to put the sensor in the 'zorst? Is it ok in the turbo exhaust housing or will that frazzle it?
Thanks in advance,
MazakMan
Old Oct 18, 2006 | 10:05 PM
Daxcossie's Avatar
Daxcossie
You want to make sure you fit a wideband lambda kit, as narrowband sensors do not work very well.
The sensor can be fitted behind exhaust (6 to 12 inch's).
Old Oct 19, 2006 | 07:33 AM
MazakMan's Avatar
MazakMan
Having just looked at the price of wideband sensors does anyone know of any cars that may be in scrappies that have wideband sensors?
Old Oct 19, 2006 | 08:07 AM
Daxcossie's Avatar
Daxcossie
Innovate Kit is around the £280 mark (XD-16 kit) on ebay. I dont know of any cars that will give you all the components you need. Best bet would be to lookaround for 2nd hand equipment. The problem with this is that the Lambda sensors dont last forever and a new one is £60 approx.
Old Oct 19, 2006 | 08:17 AM
MazakMan's Avatar
MazakMan
I had a look at that kit but i'm not sure i really need that level of sophistication, i was planning to get one of the lumenition LED meters, just so i know when something has drastically out of tune.
Old Oct 19, 2006 | 08:24 AM
Daxcossie's Avatar
Daxcossie
A cheaper option would be to buy an LC-1, wideband sensor and an anolog gauge. Graham Goode are distributers for Innovate stuff.
The main problem with the narrowband kits are that are set-up for the American market in mind and big V8's etc. Readings can show a lean setting, when in fact rich etc.
Old Oct 19, 2006 | 09:14 AM
MazakMan's Avatar
MazakMan
LC-1?
Old Oct 19, 2006 | 09:34 AM
Daxcossie's Avatar
Daxcossie
http://www.innovatemotorsports.com/products/lc1.php
LC-1 = the controller
http://www.innovatemotorsports.com/products/xd16.php
XD-16 = digital gauge with alarm setting etc
Old Oct 19, 2006 | 09:56 AM
MazakMan's Avatar
MazakMan
Thanks for digging out the links for me.
The LC-1 still seems to offer alot more than I want and I'm loathe to pay for something (albeit a very smart bit of kit) if i'm barely going to scratch the surafce of it's capabilties i.e. end up paying for stuff i won't use...
Can you see where I'm coming from?
There must be simpler (cheaper hopefully!) system for monitering lambda... maybe...?
Many many thanks again for helping me on what seems to be a deeply unpopular subject.
MazakMan
Old Oct 19, 2006 | 10:08 AM
Daxcossie's Avatar
Daxcossie
Stu @ MSD uses this one.
http://www.dynojet.co.uk/wideband/index.htm
Your engine could still run lean on a cheap narrowband setup and the gauge wont show it, so is it worth taking the risk ?
However, if your only running standard power motor you should be ok anyway.
Old Oct 19, 2006 | 10:24 AM
Daxcossie's Avatar
Daxcossie
https://passionford.com/forum/viewto...ghlight=lambda
Old Oct 19, 2006 | 10:25 AM
MazakMan's Avatar
MazakMan
I sense alot of eBay trawling coming up...
Having said that it's all a bit pie in the sky as the engine isn't even in the car yet and won't be until next year!
I may have won the lottery or been re-united with some rich relatives by the time I actually need the damn thing.
Cheers for all the advice, at least I have a clarified idea of what to look for.
Old Oct 19, 2006 | 11:32 AM
GAZ345's Avatar
GAZ345
get down the scrappies & get one out of a mondeo this will work fine with the lumenition meter, cut the mondeo loom after the plug so it makes fitting & removing easy , you will also need a boss to weld into your down pipe
Old Oct 19, 2006 | 03:55 PM
MazakMan's Avatar
MazakMan
Aha! That's the style,
cheers.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
