fuel pressure gauge
Old Oct 18, 2006 | 06:39 AM
captiva's Avatar
captiva
Default fuel pressure gauge
Can anyone tell me where to put a fuel pressure gauge and what fitting it is on 4x4 Saff. I am thinking it is between the regulator and rail or can it go the other end of the rail, which is simplest ?
Old Oct 18, 2006 | 09:43 AM
BigDave's Avatar
BigDave
Depends what you want to read really? Either weld in a fitting to the fuel rail after the regulator for proper acurate measurement. Or like me I am putting mine into the fuel line for simplicity.
Old Oct 18, 2006 | 05:26 PM
DAN P's Avatar
DAN P
or get one of these
Old Oct 19, 2006 | 02:01 AM
captiva's Avatar
captiva
If you put it in the line do you mean before the regulator if so dont I need to know the pressure at the injectors so in the fuel rail?
Old Oct 19, 2006 | 02:02 AM
captiva's Avatar
captiva
Originally Posted by DAN P
or get one of these
What is one of those?
Old Oct 19, 2006 | 10:57 AM
saphc05's Avatar
saphc05
put it between the fuel regulator and the fuel rail
Old Oct 19, 2006 | 02:45 PM
DAN P's Avatar
DAN P
that is a fule press regulator m8
Old Oct 20, 2006 | 08:07 AM
BigDave's Avatar
BigDave
I have my fuellines going through JIC dash connectors in the footwell of my car. One of these is for the fuel in and the second for fuel return. They both have the same connectors. My thoughts are that one of these will be fuel pump pressure and the return will be pressure after regulator. Its then down to you which you want to monitor.
CheeRS
Old Oct 20, 2006 | 08:10 AM
BigDave's Avatar
BigDave
This is mine...
And here are the two bulkhead adaptors, with fuel lines attached...
CheeRS
Old Oct 20, 2006 | 08:37 AM
foreigneRS's Avatar
foreigneRS
Testing the future
anywhere between pump outlet and regulator is correct
Old Oct 20, 2006 | 10:38 AM
BigDave's Avatar
BigDave
I agree mate, I want to see what my pump is pussing out more than anything.
Shame you had to break your car by the way.
CheeRS
Old Oct 20, 2006 | 11:52 AM
foreigneRS's Avatar
foreigneRS
Testing the future
thanks BigDave
Old Dec 12, 2011 | 09:30 AM
Zoggon's Avatar
Zoggon
Hello.
I need your advice. I have a standard cossie engine with one fuel rail and RS500 fuel pressure regulator, which has an addictional inlet for a second fuel rail. I read, that you advise to instal a sender between pressure regulator and fuel rail.
Right now I have a gauge installed at that addictional inlet (instead of second fuel rail) and it shows something about 3 bars when engine is at idle speed. I'm changing it to a digital one with a pressure sender.
Would it be proper if I install pressure sender into second free inlet at fuel pressure regulator? (I have only one fuel rail -standard 2wd cossie engine).
I would be grateful for any help.
thanks and best regards
Old Dec 12, 2011 | 01:52 PM
tomnsr's Avatar
tomnsr
Norway`s rs500
Should not be a problem, as rs 500 has the same pressure in both rails. the 2 connectors for fuel hoses on the regulator goes into the same chamber.
Tom.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dubs44
Sep 19, 2015 06:31 AM
