FAO Wiring Experts - Car loom connectors wanted
Old Oct 17, 2006 | 01:37 PM
AustenW's Avatar
AustenW
Default FAO Wiring Experts - Car loom connectors wanted
I've recently bought some magneti marrelli coils for my new engine and I'm stuggling to find the correct electrical connectors to fit them to the engine loom.
Does anyone have any ideas to where I could get a set of four connectors to fit these coils.
Here are some links to the coil I have
http://www.mmcompsys.com/download_zo...%20coil_01.pdf
http://www.magnetimarelli.com/racing..._RI_rev6.0.pdf
Old Oct 17, 2006 | 01:50 PM
BigDave's Avatar
BigDave
Give these folks a ring...
www.vehiclewiringproducts.co.uk
I have used them lots in the past and they are very helpful.
CheeRS
PS> Nice coil !
Old Oct 17, 2006 | 01:54 PM
AustenW's Avatar
AustenW
Will try them but I dont think they will be much help to be honest.
Who makes up motorsport looms?
Old Oct 17, 2006 | 02:42 PM
ian sibbert's Avatar
ian sibbert
http://www.wiringlooms.com/Default.aspx
DC electronics might be able to help....
http://www.servoconnectors.co.uk/
Old Oct 17, 2006 | 03:03 PM
AustenW's Avatar
AustenW
I've e-mailed all the links so far so lets wait and see.
I might try and source some from a scrap yard as a last resort.
Does anyone know of any good part finder websites?
Old Oct 17, 2006 | 03:56 PM
stevenebm's Avatar
stevenebm
post whore
try jamsport mate.theres a guy making me up a custom loom.jamie says hes in to his motorsport
Old Oct 18, 2006 | 09:40 AM
BigDave's Avatar
BigDave
Have you tried Ryan from carlooms uk?? He uses this board and made a fantastic job of my Cossy loom for the Mk2.
Old Oct 18, 2006 | 10:38 AM
Ryan's Avatar
Ryan
Not something i stock as i generally either use zetec coils or bosch coils so i have the relevant plugs for those but not for the one pictured above.
I could probably source it though, if you knew the plug manufacturer?
Ryan
Car Looms UK
Old Oct 18, 2006 | 11:03 AM
BigDave's Avatar
BigDave
There you go...
Old Oct 18, 2006 | 11:05 AM
Ryan's Avatar
Ryan
cheers for the comments dave
Old Oct 24, 2006 | 10:12 PM
PROMETHEUS's Avatar
PROMETHEUS
I have them on stock about Ł4 each
Old Oct 25, 2006 | 08:15 AM
AustenW's Avatar
AustenW
If your refering to this style of connector it will not fit at all.
These coils use a special fitting.
Old Oct 25, 2006 | 01:05 PM
DazC's Avatar
DazC
Default Re: FAO Wiring Experts - Car loom connectors wanted
I assume you have tried MM Competition Systems then? Looking at that PDF file, the order code for the plugs is AMP 284425 and is manufactured by AMP/Tyco. Any AMP/Tyco stockist should be able to get them for you but from what it looks like MM would be the most likely company to stock them.
Old Oct 25, 2006 | 01:11 PM
AustenW's Avatar
AustenW
I tried MM first when I bought the coils.
They don't seem to be able to source them.
I have e-mail all the so called specialists in the country and most have either no idea or aren't bothered.
Kevin at Viper motorsport is looking into it for me so let hope he comes up trumps
Very helpful chap
JoeyBoyden
Jan 4, 2024 02:36 PM
j.hammond1
30
Oct 31, 2021 05:28 PM
muffster
Aug 11, 2015 05:39 PM
adriansaleem
Aug 3, 2015 11:21 AM
jdsjojo
Aug 1, 2015 08:50 PM
