Anyone got a Pic of a 2WD Bottom Water Hose ???
Old Oct 17, 2006 | 08:46 AM
BigDave's Avatar
BigDave
Default Anyone got a Pic of a 2WD Bottom Water Hose ???
I am after a shot of a complete hose showing the header tank return point in detail if possible please? Also a shot showing the whole hose so I can get some idea as to dimensions and angles?
CheeRS
Old Oct 17, 2006 | 09:19 AM
STUCOS's Avatar
STUCOS
Hallo dave,will drag my car out of garage today and get pic,s for you
cheeRS stu
ps how was oz
Old Oct 17, 2006 | 09:48 AM
BigDave's Avatar
BigDave
Stu, just a shot of the hose will be fine mate. Dont go dragging your car out just for that fella.
By the way Oz was great, but I went there just for Hols. I lived in New Zealand. Also top place, but not for my lass sadly...DOH!
CheeRS
Old Oct 17, 2006 | 11:46 AM
Twellsie's Avatar
Twellsie
http://www.samcosport.com/samco.asp?make=ford
if you look on here the TCS04/C-A its the second one in from the left
Old Oct 17, 2006 | 12:11 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the bottom hose is a 3 part jobber.
the blue one goes between water pump and radiator, and has a take off to the metal pipe that runs across the bottom of the radiator and joins to the rubber hose (3rd one down) to connect to the header tank.
i have sold these parts, so can't make any measurements or anything
hope that helps.
Old Oct 17, 2006 | 01:10 PM
BigDave's Avatar
BigDave
Thanks for that Nick. Its the one with the offtake I am looking for.
Thanks to DaBoy for the link, its actually the 4/C I am looking for. I should be able to work dimensions from there and get my mate Mr Roose to knock me a custom up!
CheeRS lads
Old Oct 17, 2006 | 01:16 PM
BigDave's Avatar
BigDave
Stu, I will have a snap if you do drag the car out mate? I could do with seeing how the offtake from the bottom hose clears the alternator belts? I am guessing they must run round the back or right through the middle?
CheeRS
Old Oct 18, 2006 | 09:49 AM
BigDave's Avatar
BigDave
Has anyone got a shot or description of what route the small take off line takes on the bottom rad hose?
CheeRS
Old Oct 18, 2006 | 10:26 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it goes to the metal pipe that is fixed to the bottom of the rad as i said above. don't know if that's what you mean? all of that is well in front of the belts
Old Oct 18, 2006 | 11:06 AM
BigDave's Avatar
BigDave
Nick, I mean the actual elbow when it leaves the bottom hose. What orientation does it initally take? Does it go round the back of the belts or pass through the middle of them?
My car looks tight for space and I have a different rad fitted with it being in a Mk2 Escort.
Will see if I can find a pic.
CheeRS
FlashRS
13
Aug 31, 2015 06:02 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
borboyous
Aug 22, 2015 11:17 AM
john_3.0s
Aug 15, 2015 07:44 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
