White Smoke *UPDATE*
Old Oct 16, 2006 | 09:48 PM
Escort.Cosworth's Avatar
Escort.Cosworth
Default White Smoke *UPDATE*
Car has started to give white smoke on tick over? car was just sitting ticking over and there was 100s of white smoke
Cant say this is normal as it wasnt like this before
S2 rs btw
Old Oct 16, 2006 | 10:18 PM
©hatter Box's Avatar
©hatter Box
oh dear head gasket swap over
Old Oct 16, 2006 | 10:27 PM
Escort.Cosworth
Old Oct 16, 2006 | 11:09 PM
Escort.Cosworth
Just been out and the smoke clear's after a few mins so hope head gasket is ok as its not long been done
Old Oct 17, 2006 | 09:39 AM
scotty86d's Avatar
scotty86d
could it be condensation or is it way beyond that?>
Old Oct 17, 2006 | 01:27 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
when its sitting just after start up or in general?
Old Oct 17, 2006 | 05:22 PM
steven botes's Avatar
steven botes
remove the tappet cover and check that your valve stem oil seals have not hardend and lifted. when they float on the stems , they act as pumps and force oil into your exhaust manifold ans cause endless white smoke
replace with the newer top hat valve stem oil seals
Old Oct 17, 2006 | 05:27 PM
buggynut's Avatar
buggynut
second that new valve stem seals
Old Oct 17, 2006 | 09:32 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Agreed, hence why i asked about start up sure way of knowing if its the valve stem seals
Old Oct 17, 2006 | 09:50 PM
Escort.Cosworth
*UPDATE*
Car has been down at the garage and has had a compression test and all fine
Car boost's fine just white smoke likes to come out the exhaust for some reason Also have been told might be something to do with the breathers been blocked? Going to take all the pipes ect off and give them a good clean and hope for the best
Cars using water aswell
Old Oct 17, 2006 | 10:49 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
You should be able to smell, whether it's burnt oil or burnt coolant. Bright white smoke is usually water/coolant.
A garage can check your coolant for signs of exhaust gases.
Old Oct 17, 2006 | 10:56 PM
Escort.Cosworth
Cant smell anything mate The garage said everything was ok and that the oil pump needs changed and a new turbo but the car boost's spot on ect Even when the car is on boost theres no smoke
Bloody car
Old Oct 21, 2006 | 09:44 AM
Escort.Cosworth
Still cant get to the bottom of the problem so going to get the valve stem oil seals done i think and see if that will solve the problem.
Bloody cars
Old Oct 21, 2006 | 10:11 AM
user 7082039239
You must be able to smell something...
If it's loosing coolant it will most probably be burnt water. Burnt oil would have a very characteristic smell and the smoke would be more blueish than white.
Get the coolant CO-tested. Will only take a few minutes.
Old Oct 21, 2006 | 11:11 AM
nigel b's Avatar
nigel b
try looking at the breather system if it does this only when cold
Old Oct 21, 2006 | 12:25 PM
antony215's Avatar
antony215
Escort Rs Turbo
As said above you sure it's not just condensation as it has been cold the last few week's and like pete say's valve stem's is usaly blue smoke.
Old Oct 21, 2006 | 05:03 PM
Escort.Cosworth
Nope cant be condensation theres loads of smoke and it wont go away When you take the oil cap of theres steam that comes out there now This normal?
Old Oct 21, 2006 | 05:09 PM
antony215's Avatar
antony215
Escort Rs Turbo
Might be a sign of the headgasket starting to going then mate
Old Oct 21, 2006 | 05:11 PM
Escort.Cosworth
Cheers mate Didnt think it would have been as its just been done a few months back
bobsworth
77
Mar 24, 2016 09:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
