CHARGE COOLER OR INTERCOOLER?? ON RST
Old Oct 16, 2006 | 09:45 PM
bigsjay's Avatar
bigsjay
Default CHARGE COOLER OR INTERCOOLER?? ON RST
SO WHATS BETTER TO HAVE OUT OF THESE? IM NO EXPERT BUT ISNT A CHARGE COOLER BETTER THAN A INTERCOOLER OR AM I WRONG?
Old Oct 16, 2006 | 09:48 PM
bigsjay's Avatar
bigsjay
AND WHAT MAKES DO YOU THINK ARE BEST?
EIL132's Avatar
EIL132
100% wrong, but it totally depends on what you want the car for. 1/4 mile the chargecooler has benefits, track intercooler
Old Oct 16, 2006 | 09:50 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
chargecooler all the way IF it was big enough, but its not if you talking about the ones you generally get for em.
same as that size intercooler is too small too.
of the stuff available, a big front mounted cooler is best
Old Oct 16, 2006 | 10:03 PM
bigsjay's Avatar
bigsjay
if it was a cold day which out of the 2 work better? just wondering thats all.so what front intercooler is the best?
Old Oct 16, 2006 | 10:43 PM
EIL132's Avatar
EIL132
You live in Iceland, or just drive the RST in winter Pro Alloy or GRS, either that or make a Cossie 4x4 fit.
Old Oct 16, 2006 | 10:46 PM
Keith B's Avatar
Keith B
Chargecooler of you have a big enough 'radiator' for it although alot of pumps you buy are unreliable. Intercooler is lighter, simpler and if you can get the air flow to it jsut as good. Liquid has better conduction properties of course but making one big enough for big boost and making it reliable is another thing.
Old Oct 17, 2006 | 07:42 AM
Eagle's Avatar
Eagle
Super Moderator
all depends on what stage of tune you want to goto ..
i ran a charge cooler for a while on the sII at 15psi .. but once the power was upped to 24psi it stood no chance if your looking to run big power you need a big intercooler .. but with that can bring cooling issues due to it blocking off the majority of the radiator ...
but there are ways of sorting that out with a twin fan setup, and thermostat modifications and fit a nice big ally rad
Old Oct 17, 2006 | 01:59 PM
bigsjay's Avatar
bigsjay
so whats the differences between pro alloy and grs .which is better do you think?
Old Oct 17, 2006 | 02:41 PM
Rab's Avatar
Rab
Fucking superstar........
Big intercooler. Any day of the week.
Old Oct 17, 2006 | 02:58 PM
b3nle's Avatar
b3nle
blow on your finger, now lick it and blow on it. chargecoolers are king.
Old Oct 17, 2006 | 03:04 PM
Gregs's Avatar
Gregs
get an escort cos std intercooler/charge cooler, then you get the best of both
Old Oct 17, 2006 | 03:08 PM
cheeky dog's Avatar
cheeky dog
pro alloy but GRS and Pace are good too.
Old Oct 17, 2006 | 03:50 PM
Micky's Avatar
Micky
Rubbish,rubbish and rubbish again.As siad above in previous posta a large intercooler is the best.The chargecooler kits that are generally available dont have a large enough rad and the pumps are unreliable.Also the whole chargecooler system is too complicated with more to go wrong.Lastly they weigh more.Regards ,Micky
Old Oct 17, 2006 | 07:09 PM
Eagle's Avatar
Eagle
Super Moderator
at 16 psi plus you will have no chance with a chargecooler .. i have been there .. my pace one lasted about 2 months, it was a trial to see if it would handle any power .. and it couldn't .. you get to a point where the water supposedly cooling it is as warm as the air its trying too cool..
i had a grs version 2 with an ally rad and a twin fan setup.. on track at national day 5 years ago running 24 psi i saw a max of 50deg c air charge temps
Old Oct 17, 2006 | 07:13 PM
Oranoco's Avatar
Oranoco
Have a charge cooler on my Fiesta and a big Pace intercooler on my Escort. The intercooler wins hands down.
Once I've got some more cahs I will be seeing if I can mod a Pace cooler to fit the Fiesta
Old Oct 17, 2006 | 07:14 PM
Paddy's Avatar
Paddy
Legend
That gave me the horn.
Old Oct 17, 2006 | 07:16 PM
Stoo's Avatar
Stoo
I had a chargecooler on my old ERST but changed to a big front mount IC. Don't really know why...but i just didn't trust the chargecooler for some reason
Old Oct 17, 2006 | 07:19 PM
Paddy's Avatar
Paddy
Legend
Did it look shifty and have an Irish tinker accent?
I'm bored.
Old Oct 17, 2006 | 07:30 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
I've run a chargecooler for 9 years - never had a problem and recommend them.
Old Oct 17, 2006 | 07:37 PM
EIL132's Avatar
EIL132
Boil a kettle and stick your finger in it, then try blowing it to cool it down. It's called heat soak
Old Oct 17, 2006 | 07:42 PM
Eagle's Avatar
Eagle
Super Moderator
Old Oct 17, 2006 | 08:45 PM
GavStyli's Avatar
GavStyli
Kasapis
quality reply
gcfcos
59
Oct 6, 2015 05:04 PM
