Finis number
Old Oct 16, 2006 | 02:34 PM
Franco's Avatar
Franco
Default Finis number
anybody know the finis number for these???
http://cgi.ebay.co.uk/GGR1209-4x4-Co...QQcmdZViewItem
As i bet a pound to a penny they're cheaper from Frauds! but cant find them on microcat.
Old Oct 16, 2006 | 06:15 PM
GUZZLER's Avatar
GUZZLER
there on the microcat in the cylinder head section, shown in an exploded diagram in front of the cams.
i think there about £20 each from fords, cheapest way would be to take 1 of your old bearings to a bearing specalist & get them to match it up.
Old Oct 17, 2006 | 01:00 AM
G1EN's Avatar
G1EN
graham goode trade quite cheap on ebay mate.
I buy my cam cover gasket at half the price of fords...
Old Oct 17, 2006 | 06:44 AM
Franco's Avatar
Franco
Hmm........... Nowts ever easy on 4x4's is it!
Might see whats what then, i always thought GGR were alittle keen with some of thier prices.
Old Oct 17, 2006 | 08:58 AM
Franco's Avatar
Franco
Anybody know if its No29 i'm after?!?!
Old Oct 17, 2006 | 11:11 AM
Dave Henshall's Avatar
Dave Henshall
no 29 is correct m8
Old Oct 17, 2006 | 11:12 AM
Dave Henshall
as aboev though, there will be a number on it somewhere - you should be able to x-ref that against a SKF standard bearing and pay only a few £ each
Franco's Avatar
Franco
I love you Dave!
Old Oct 17, 2006 | 11:19 AM
Franco's Avatar
Franco
Is that a good option then? where the hell would i find a bearing place..........
Whats one look like!
Old Oct 17, 2006 | 12:40 PM
GUZZLER's Avatar
GUZZLER
Franco, Ford finnis; 6542 370, £9.51 plus vat........
but showing removed from service.
Old Oct 17, 2006 | 12:53 PM
Franco's Avatar
Franco
Then i'm off to see some bearing companies this weekend then!
Old Oct 17, 2006 | 01:59 PM
Dave Henshall
most local engineering places will have a SKF book, in macclesfield there are companies like Macc bearings, Delaneys hardware etc,
they basically measure the internal and external dimensions, the type of bearing and this will denote a bearing code, something like in this table:
http://www.skf.com/skf/productcatalo...ableName=1_1_5
Old Oct 17, 2006 | 02:12 PM
Franco's Avatar
Franco
And SKF are the best then Dave? Just in case they try to fob me off with some old bollox!
Old Oct 18, 2006 | 07:23 AM
Dave Henshall
there are a few makes about, SKF, Timken etc, its generally the bigger firms that offer the full cross reference services though, i wouldn't be too worried though, as it does run in engine oil that is pumped up to the top of the head, if it were a 'sealed for life' bearing that is pre lubed i would want a well known make..
Old Oct 18, 2006 | 07:38 AM
Franco's Avatar
Franco
See the thing is Dave, i've had my fingers burned with this project regarding taking the CHEAPER option......... But i do know what you're saying!
I took the exh bearing off yesterday & its deffo a SKF bearing anyway.
SKF - 6205N (last letter COULD be a M) - France
But would the bearing look exactly like the one in front of me, IE have the outer ring on the bearing casing (if that makes sense, has the cut out so you know which way it sits on the cam).
Old Oct 18, 2006 | 09:01 AM
Dave Henshall
so if you go on the skf site you can put in that code and it will give you all the critical dimensions,
(here you go)
http://www.skf.com/skf/productcatalo...=false&lang=en
abnd yes that DOES come with a snap ring groove already in it - result
Old Oct 18, 2006 | 12:52 PM
Franco's Avatar
Franco
Cool, i take it the snap ring is readily available from Frauds still?
Old Oct 19, 2006 | 08:30 AM
Dave Henshall
probably comes with the bearing, i would have thought... but its not an item that would wear like a bearing though - so if it doesnt't, i wouldnt bother replacing it....
Old Oct 19, 2006 | 08:32 AM
Franco's Avatar
Franco
Thanks Dave, is this what you did BTW?
Old Oct 19, 2006 | 10:35 AM
Dave Henshall
nope, after all that - i got mine from simon at Woodford motorsport,
as i was getting new belt, filter, tensioner, full gaskget set, valve guides valve stem seals, hoses, core plugs, header tank, turbo heat shield and bottom splitter all at the same time i got them with that little lot - and THEN found they were a SKF bearing that i could have got cheaper myself - cos i got all this bits BEFORE stripping it down - doh - in for a penny in for a pound eh
Old Oct 19, 2006 | 10:41 AM
Franco's Avatar
Franco
Thats the only concern i have Dave, after the fiasco with my cam trigger etc i don't want to be a cheap fecker & end up ruining the engine / head!
rsguy
44
Sep 29, 2015 03:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
155lee
Sep 23, 2015 01:27 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
focus2351
Sep 9, 2015 09:33 PM
