fao people with cossie brakes on their rs turbo
Old Oct 15, 2006 | 10:58 PM
EssexMikeSi's Avatar
EssexMikeSi
Default fao people with cossie brakes on their rs turbo
what braided brake hoses have u got? and where did u get them from. its doin my head in this is, no one can tel me a definete answer. i need braided brake hoses for the fronts and for the rear callipers ive put on. they are saph 4x4 callipers all round, but obviously the brake lines comin from the master cylinder are original escort ones. i wondered if u just get normal escort rs turbo braided hoses, or if the end that join the calliper are different from cosworth to rs turbo if that makes sense
help lol
Old Oct 15, 2006 | 11:14 PM
xrchris's Avatar
xrchris
would think most are very similar mate. fittings i would have thought are the same but length maybe a bit different.
i'm in need of some braided rear for mine front already has them. got some sort of cossie calipers on the back lol
Old Oct 16, 2006 | 12:00 AM
scotty86d's Avatar
scotty86d
the rs turbo goodridge lines fit the 4x4 callipers ive been told by many people so id go with that.
Old Oct 16, 2006 | 02:30 PM
EssexAaron's Avatar
EssexAaron
you need RS turbo ones on the front
and custom made set for the backs
Old Oct 16, 2006 | 06:45 PM
EssexMikeSi
hve u ever had it done aaron? or do u still have drums at the rear? if so, where did u get them done plz mate
Old Oct 16, 2006 | 07:02 PM
turboloon's Avatar
turboloon
Default 4x4
i've been told that the 4x4 front calipers are exactly the same caliper as the s2 just that they ran with better pads and bigger discs...so as above iwould go with rs turbo braided front lines i'm running 2wd cossie front calipers they're 4 pots and a slightly diffrent set up....
Old Oct 16, 2006 | 07:05 PM
Turbo-Beal's Avatar
Turbo-Beal
Iv just done a 4x4 rear disk conversion on my projet and got my rear braided brake hoses from burton power online. Im pretty shure the standard ones for the front will fit fine. Hope this helps
Old Oct 16, 2006 | 09:46 PM
ivorbiggun's Avatar
ivorbiggun
Standard size RST for the front then messure up the rear and go to your local Pirtec man who'll make them for you for 30 quid.
Old Oct 16, 2006 | 11:31 PM
EssexAaron's Avatar
EssexAaron
abby hose mate.
make em while u wait
Old Oct 16, 2006 | 11:40 PM
Gregor's Avatar
Gregor
Hmzz..I got 2wd callipers on my rst.... had to order special ( braided) hoses... dunno if the 4x4 callipers have the same connection though
Old Oct 17, 2006 | 11:46 AM
Wazzzer's Avatar
Wazzzer
I got mine from Mike Rainbird, sorted me out a custom set for about Ł50 (Cos 2WD calipers all round)
Old Oct 17, 2006 | 06:36 PM
EssexMikeSi
cheers for the replies everyone, been a great help. and its also made me realise, im gona ditch my 4x4 front callipers and get 2wd ones
Old Oct 17, 2006 | 07:06 PM
scraggyrst's Avatar
scraggyrst
does the same apply for using 2wd calipers on front with 2wd discs
Old Oct 17, 2006 | 07:28 PM
Turbo-Beal's Avatar
Turbo-Beal
I was going to put 2wd cossy calipers on the front of my car but im am going away from the idea for the following reasons
First you will have to machine the caliper mounting points 4mm to get the correct spacing, secondly i think you will find you will have to use a banjo bolt fixing on the brake pipe to the calipers due to clearance problems and thirdly i was told to use 4x4 cossy front disks for the correct diameter. As well as the issues iv mentioned above you would also have a problem with which wheels you can use cuz they stick out further and rub on the inside of your alloys I would suggest the 4x4 cossy front calipers is the better option and less of a pain.
Old Oct 17, 2006 | 09:25 PM
ivorbiggun's Avatar
ivorbiggun
Just stick with your S2 calipers on brackets (Ł40 off Clint on Turbosport)
these mount your calipers slightly further outboard on the discs than 2 or 4 w/d cossie calipers sit/therefore giving greater resistance to the rotational forces on 285mm discs ie better brakes!
Then put you cossie calipers on Ebay/should get 50 quid for them/and enjoy
the new found tenner at your local Beer vendor.
The above system bolts straight on, no machining and no spacers to worry about/loose every time you dismantle them.
Although you won't be able to 'astound' your mates in the pub with tales
of your cossie calipers...Yawn!
Old Oct 17, 2006 | 10:24 PM
craig rs's Avatar
craig rs
my whole brakeing system is braided lines brought a good length of braided hose and all the fittings and made them up myself
www.speedflow.co.uk everything u could possibly need
Old Oct 18, 2006 | 12:04 PM
zetec-turbo's Avatar
zetec-turbo
rear braided lines for rear disc conversions are available from burtons, as mentioned above..........
failing that as mentioned here get 'em made straight thro to your calipers from cylinder from abby hose while you wait
Old Oct 18, 2006 | 06:15 PM
EssexMikeSi
cheers for the replies. yea gareth, i just looked on the burtons site, and found the hoses for rear discs. hopefully it would have the right fittings on each end. i had looked on burtons site a few months back wen the car was started but they didnt list them at the time
Old Oct 19, 2006 | 12:18 PM
ballin's Avatar
ballin
mike rainbum will sort u!
Old Oct 22, 2006 | 09:38 AM
EssexMikeSi
has anybody got a pic of their front brake set up? im particularly interested in seeing the calliper carriers if possible
Old Oct 22, 2006 | 09:56 AM
Turbo-Beal's Avatar
Turbo-Beal
Hope this helps
Old Oct 22, 2006 | 11:48 PM
EssexMikeSi
blimey thats mint mate, nice one. have u got same cossie set up on the front? sorry forgot t put in my post, but i meant i needa pic of front brake set up
Old Oct 22, 2006 | 11:52 PM
EssexMikeSi
infact the more i look at that, the minter it seems. did u have the bodyshop do all the painting of the chassis rails etc wen they painted rest of the car? i wana do all the arches etc on mine bodycolour
Old Oct 23, 2006 | 05:25 PM
Turbo-Beal's Avatar
Turbo-Beal
Sorry m8 but i havnt yet got around to fitting the front calipers yet so no pics I am going to put the standard ones back on the front for now until i decide wether to put my 2wd calipers on or opt for willwood or hi-spec brake setup. The 2wd calipers seem like too much hard work
As for the underneath i painted myself with 2k paint, compressor and spray gun Its all in my resto tread if you are intrested https://passionford.com/forum/viewtopic.php?t=211254
P.s havnt had a respray on the shell yet. its as i bought it The paint is pretty good overall but eventually i want it done to make it A1
Billy_RS
16
Oct 11, 2025 09:41 PM
carlo
24
Oct 5, 2015 08:20 PM
Bailes1992
Aug 16, 2015 07:14 PM
Red_bull
Aug 9, 2015 08:34 AM
