low comp engine
Old Oct 15, 2006 | 10:02 PM
Maxxeh's Avatar
Maxxeh
Default low comp engine
hi guys, what does low compression pistons actually do? im a n00b at this. whats the advantages?
Cheers.
Old Oct 16, 2006 | 12:02 AM
scotty86d's Avatar
scotty86d
means you can run more boost generally(if you dont have a flash engine manament systems) with a lower risk of detonation i think
throttle response off boost suffers though
Old Oct 16, 2006 | 10:18 PM
Maxxeh's Avatar
Maxxeh
ive got the .5 mahle low comp pistons. i read sumwhere that they dont like to be redlined. is this true?
Old Oct 16, 2006 | 10:59 PM
Andy_R's Avatar
Andy_R
.5 relates to the piston being .5mm oversized.
Lowering the compression ratio increases the scope for additional ignition advance and or boost.
Old Oct 17, 2006 | 05:32 PM
steven botes's Avatar
steven botes
ran Mitsubishi Tredia/Vortex Turbo 1800 4g62b 80.5MM pistons for 5 years at a cr of 6 to 1 - ran 2 bar boost with a t34 on pump fuel without too much stress , donkey low down but strong past 3k
Old Oct 18, 2006 | 06:39 PM
NEWTON's Avatar
NEWTON
comp ratio of 6-1 thats a bit drastic ant it
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Aug 27, 2015 08:56 PM
ekjim
Aug 17, 2015 08:57 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
