hi all turboing my 1.1?
I would get a doner car as you will need alot of part's and buying them separately will cost a lot more you will need full loom, ecu, engine, turbo, intercooler, rad fan, gearbox, fuel pump, hose's water/boost, brake's rs/xr2i, breather, system exhaust, engine mounts, suspension/anti roll bar, lower arms, link arms
tbh mate if you got a donor car n transplanted it you'd be much better off just having the standard frst.
also insurance is going to be worse on an engine converted fiesta than a frst.worth a thought.also you'd be luck to get change from at least a grand
personaly i think ud get some good cash for your car as it is and put that towards a frst.
sleepers are cool but be realistic
standard looking fiesta mk3's look pants
yer but frst's now days are rotten and this 1.1 is as solid as a new fiesta and has only surface rust which has now been termineted!and how will the insurance be more expensive thatn on a frst?also i know it looks shite but imagine it lowered 60mm,bbs alloys,big FMIC at the front and a 4"outrolled pie straight through,the only way people will be able to tell it is rs turbo powered is by the chatter,intercooler,and pipe.the interior wil be rs turbo interior also
yer ive seen it done before to a car for sale on ebay,it was a real bodge job!!he had a plastic pipe from the carb to a t15 turbo off a cinquecento-(vannaken conversion) and no intercooler
if you did what to turbo the 1100 lump get yourself a mk1 fiesta inlet manifold as the bolt spacings for the carburetta match up with the renwot R5-GTT carb
when i get a reasonable priced carb off ebay..........maybe
not on a road car quite yet though
there was a 1.3 turbo x'flow on ebay the other day simular design to the 1.1
Sideways in that
i would just buy a rotten fiesta turbo and put the enginem running gear and seats into the 1.1, alot easyer, maybe some alloy wheels but not to bling or u will lose the "sleeper look", upgrade the brakes also , its good to have the power and speed but better to scrub it off as fast as u can get it tho
1.1 turbo?anypoint?this car was scrapped 2 months ago anyway to fund another oproject
http://cgi.ebay.co.uk/mk3-fiesta-xr2...160077901877QQ ihZ006QQcategoryZ21654QQrdZ1QQcmdZViewItem
JK12
33
Apr 26, 2021 12:09 PM
