My car is now breaking
Fucking superstar........
Right. Now breaking, All parts available.
Engine Parts
Fiesta RST bottom end. Milage unknown. Looks good, no marks on the tops of the pistons and the bores look good. £200
Piper 285T2 Camshaft and vernier pulley. Comes complete with it’s own complimentary cracked EFI head. £80 Prov Sold
Garret T2 Turbocharger. Just been rebuilt at a cost of £175. Still under warranty from GB Turbo solutions for 6 months/6000 miles. Warrantly will be honoured as I’ve never used it. Comes on coated FRST exhaust manifold and with all oil/water pipes needed. £250
XR2 Type exhaust for Turbo applications. Custom made 2.5” Bore single silencer system. Has a T2 downpipe on it right now but could easily be converted to a T3 downpipe. £100
OFAC Loom and ECU/Map sensor with all sensors and coilpack etc. £100Prov Sold
Superchips 165 Chip £50 Prov Sold
Efi Inlet and injectors, throttle body etc £40
Powdercoated black rocker cover x2 £20 each
EFI crossover pipe black £10
EFI crossover pipe silver £10Sold
Samco hoses for T2 Fiesta Turbo with coated hard pipes and K+N Filter £50
Little stainless steel oil separator tank. £20Prov Sold
S2 RST LSD Gearbox. Recently rebuilt, no noises, £120
Suspension and Brakes
Mondeo V6 calipers and discs. Straight bolt on fitment to your XR2 with goodridge braided hoses £100 (Note you will need 15” wheels to fit these)Prov Sold
Spax VSX 40mm suspension kit. Done approx 3000 miles. Good contions no leaks etc. £120Prov Sold
Wheels and tyres
15” Escort Gti alloys, with newish 195/45 Yoko A539’s front, and good tread A520’s rear. £150Prov Sold
Interior
2 buckets seats of unknown make, look like Cobra Clubmans on XR2 Runners. £100Prov Sold
3 point harnesses x2 Black. £50Prov Sold
Autometer Boost gauge £20Prov Sold
Autometer AFM gauge with no lamda sensor £20Sold
That’s really all there is inside the car…….
Shell
Good clean rot free shell. In Diamond white. Welded in multipoint roll cage with doorbars and rear diagonals. Had a small patch on the inner wing at some point. MOT until July 2007, with ID and V5. Taxed until March 2007.
Shell will have as much left on as you wish, but as a guide. Without suspension, but with all other running gear, and car loom, dash, clocks, and everything else like glass, master cylinder etc, fuel pump will be left on. Basically, to make it rolling you’d need suspension kit, front brakes and some wheels…
Price for this would be £350Prov Sold
The shell can have as much left on it as you wish. But no less than the above.
It’s really painful to do this. But life’s a bitch I suppose…..
PM or call 07835 296 463
Engine Parts
Wheels and tyres
Interior
Shell
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
