injectors not firing
Old Oct 15, 2006 | 10:07 AM
cossie power e30's Avatar
cossie power e30
Default injectors not firing
I brought a e30 bmw with a cosworth engine running 270 bhp about 18 months ago.I wanted more power so removed the engine and rebuilt with all uprated parts.now the fuel pump has no power going to it and the injectors are not firing.
does the front crank pulley have anything to do with the firing of the injectors?
does anyone have a 2wd colour wiring diagram and ecu pin number diagram?
iv also fitted a swedish plenum and had to cut the loom and extend the wires thats why i want to start at the begining and check everything.
iv tried ecu,crank sensor,3 bar map sensor on another car and all worked fine
any info will be a big help thanks
Old Oct 15, 2006 | 12:53 PM
velocity's Avatar
velocity
pm me an email address and i can send some diagrams that should help.they are difficult to read from the website
Old Oct 15, 2006 | 06:11 PM
velocity's Avatar
velocity
email sent its a bit big so i hope it opens for you
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
DixieTheKid
Sep 14, 2015 09:04 PM
